Author Topic: what will be a good cheap lift kit  (Read 6219 times)
bayou bogger
  • Male Posts: 26
  • Member since Sep '11
« on: Nov 30, 2011, 09:03:50 AM »
I want to squeeze 35in mud tires on my 1979 toyota pickup truck what are some good cheap lift kits on the market. I looked into All Pro lifts they are way out of my budget plus they look like they require allot of time to put on
P.S. I do not want to use lift blocks.
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
Re: what will be a good cheap lift kit
« Reply #1 on: Nov 30, 2011, 10:23:09 AM »
Ruf and chevy 63, or f150s. Or, no lift and some fender trimming, I did that before I did anything to my old truck
bayou bogger [OP]
  • Male Posts: 26
« Reply #2 on: Dec 01, 2011, 02:25:41 PM »
are saying a rough country lift kit for a chevy 63 or f150 will fit my truck. Or do you mean you use the springs off these year model trucks. Little confused on what you meant.
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #3 on: Dec 01, 2011, 03:04:57 PM »
Search around. Lift kits ride like crap. Ruf is rear springs up front. For the rear Chevy 63s or f150 springs require cutting off your old spring hangers and welding new ones on
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Dec 01, 2011, 04:29:03 PM »
Shackles and a decent spring pack will do the job keep it to a minimum since the more you lift the more that will have to be done to correct the steering geometry issues that will come up. The more you lift with the push pull steering the more it will pull the geometry out of line an adjustable draglink will correct this issue. If you don't mind a harsh ride the OEM length ready to install springs from the big box suppliers.
blumagoo
  • Turtle Points: 2
  • Member since Jul '10
« Reply #5 on: Dec 01, 2011, 05:13:57 PM »
3" body lift should fit those 35s for about a hundred bucks or less.
Jokeass-Wheelers
  • Turtle Points: -5
  • Male Posts: 429
  • Member since Aug '10
  • toyota 4X4
« Reply #6 on: Dec 01, 2011, 06:58:49 PM »
i got toy add a leaf and 3in body lift got it by trading some stuff cut a little fender and i fot 37s without rubbing
11 Jokeass-wheelers 7
1985 Toyota 4runner 22re 4x4 5:29 38in tsl's
IF IT LOOKS LIKE A PIG SMELLS LIKE A PIG IT MIGHT BE A PIG
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
« Reply #7 on: Dec 01, 2011, 07:06:12 PM »
If you want to really do it cheap and easy get some extra stock leaf packs to add to the rear springs and a set of rears up front with and extral leaf or so with a re-drilled center pin hole so they work with the stock steering.  I used these with longer shackles and a set of longer shocks and the results are pretty good. More travel, better ride quality and very inexpensive.  You can net about a 2-2.5" lift, maybe more if you do the j-ball flip on your steering.  With a little triming and hammering on the firewall seams you should be able to run 35s.
As stated above, cheap lift springs really suck.
– Steve McQueen
BadnewsBob
  • Turtle Points: 9
  • Male Posts: 350
    • Buy me a soda
« Reply #8 on: Dec 01, 2011, 09:21:20 PM »
Get the springs off of a 2wd chevy or ford F150 That is what they are talking about,  Toyota rears up front. That is how mine is done.  Cheap and works great.
AE2 USN ret
No matter where ya go..... there ya are.
Hillbilly Offroad
84 xtra cab on 63" chevies and RUF 35" KM2s 22R 5 speed DTC 5.29s Locked front and rear.
4x4yota
  • Turtle Points: 301
  • Male Posts: 1,256
  • Member since Oct '07
« Reply #9 on: Dec 04, 2011, 05:50:56 PM »
just leave it stock and throw the 35s on they should clear already as long as you get the back spacing right...
I ran 35s on an old 1980 bone stock just hammered the pinch weld and never looked back... Im currently running 33s and could easily step up to 35s again
Current:
Sold:
Jokeass-Wheelers
  • Turtle Points: -5
  • Male Posts: 429
  • toyota 4X4
« Reply #10 on: Dec 05, 2011, 07:32:11 AM »
true onm my 1982 i put 35s on it it looked like it had a 4in lift on it never really rubbed too bad and actually did decent on the road  :driving:
  • Momentum Man
  • Lego Enforcement
« Reply #11 on: Dec 07, 2011, 12:26:11 AM »
Don't go over 2" body lifts, too many mods need to be done and the shifters get real short plus the floor may need to be cut and the boot can cause it to pop out of gear.
Jokeass-Wheelers
  • Turtle Points: -5
  • Male Posts: 429
  • toyota 4X4
« Reply #12 on: Dec 07, 2011, 06:16:30 PM »
my step dad did chevy springs front and rear but they were not chevy 63s they were like chevy 53s and he fit 39.5s
Last post Sep 07, 2005, 12:28:44 PM
by miks85yota
Last post Jan 28, 2006, 11:02:43 PM
by yotatilla
Last post Apr 17, 2006, 06:05:11 PM
by 79coyotefrg
Last post May 25, 2006, 11:50:12 AM
by blackdiamond
Last post Jul 11, 2009, 04:38:12 AM
by jimbo74
