help wiring up arb locker switch
Started by Yota4life, April 14, 2006, 12:00:57 PM
Yota4life
I have the silenoid all set up and air line ran i just need to wire the switch now. What wire and where can i splice into the ignition? like arbs wire diagram says. I have to splice into the dash illumination too..Do these wires run to where the kick panel is on the driver side? Any help needed, thanks
Lady Di
in case it moves before you get a chance to see it. DirToyBoy found this:
Today at 04:33:35 pm DirToyBoy - AR- did you look on 4x4 wire here    http://www.4x4wire.com/toyota/tech/electric_locker/
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Yota4life
Thanks for posting that but, im not doing an electric locker.
Lady Di
I don't know if MrW saw this thread yet. I'll point it to him when he gets on later. We've got ARB air lockers.
Willy Mammoth
#4
Quote from: MrsWillyMammoth on April 14, 2006, 01:38:46 PM
:slap:
Wimmins  :shake:
I believe there is a Bat connection that carries the load of the compressor so the Ign. wire only powers the relays and solenoids.
You can connect that to almost any circut that is controlled by the IGN. switch. Or tap into the IGN wire comming off the key switch so long as there is an in line fuse and I remember there being one.
The illumination only lights up the switches so you can see them in the dark. So find a wire that goes to your instrument panel you can tap into for this. Maybe you have a light in the ash tray?
BTW, that ARB harness has more wires than I have in the Mammoth.
Yota4life
Ya i just have the switch and silenoid no wires or anything...i figured it out though. I just ground the silenoid and run another wire to the switch. I can splice into the heater fuse down on the drivers kick panel and the dash lights on the fuse panel also.
Thanks for the help
