Author Topic: Three things I'm stoked about modifying  (Read 8527 times)
gferris5
  • Turtle Points: 7
  • Member since Oct '02
« on: Nov 01, 2003, 09:38:07 PM »
 :driving:
Howdy, I figured, hey, why not be the first person to post up on this board. Okay so there are three things I've recently done to my truck that I'm really stoked on.  Here is my brief write up:
1. Clutch master Cylinder:
Tools: Needle nose pliers, 3/8s drive w/ 6" ext and a swivelly joint with a 12 millimeter socket on the end. 10 millimeter flare-nut wrench, Brake fluid, and some rags
1. pull  cotter pin connecting master cylinder piston to clutch pedal w/needle nosers
2. disconnect fitting- 10 mil flare nut, loosen it and soak up fluid with rag-keep your paint happy.
3. Undo bolts holding MC to the firewall.  Pull
4. Install is reverse of removal-bleed lines, adjust pedal for proper height and freeplay.  Height I think is 5 and about 1/8 inches-consult manual, and freeplay is between about an 1/8 and 5/16.
5. now your foot won't slip off your slippery, brake fluid covered clutch pedal. Mine feels great and added a much more linear feel to my clutch.
3 row radiator and 180F thermostat.
1. Watch temp needle rise-cuss.
2. get yourself a three row radiator from a reputable source, I got one that was designed for a V6 second gen, but connected it to my 22re-150% more cooling capacity-booyah.
3. pull off fan shroud, drain coolant, disconnect hoses-cuss at mud clogged radiator-pray for a functional head gasket!.  Put fancy new radiator in
5. change the hoses you lazy cheapo, it's worth it
6. replace t-stat, don't tighten dem bolts too much, you don't want to crack the housing. also put some RTV to help the seal.
7. double check everything, put back on fan shroud, fill with water and coolant.
8. dispose properly of used coolant-keep the environment and your pets happy.
9. start motor with cap off of radiator-bubbles? no, phew
10. Drive back to school and watch that gauge stay steady no matter what.
And finally the best:
Under hood light.
1. Go to junkyard
2. locate dodge caravan-there are tons of these things!
3. Rob the suspension off of it and put in on your rockcrawler.
4. step #3 was a joke)
5. lift the hood and remove the light with a tiny little socket (8 mil?)
6. Cut the wire such that the little connector is still attached to light-you'll be glad.
7. use some self tapping screws and mount the light to the underside of your hood
8. Run a wire to the battery
9. I had to run a ground wire to the firewall because it wouldn't ground through my hood.
10. enjoy the gravity switch that turns it on when you open the hood or go up a steep hill.
That's all-very in depth I know, but these are three things that I did that I'm way stoked on. I know you will be too! And boy, so difficult, I don't even know how I did it!
enjoy!
gferris5 [OP]
  • Turtle Points: 7
Re:Three things I'm stoked about modifying
« Reply #1 on: Nov 12, 2003, 07:43:48 PM »
What? nobody thinks this is even a little funny?
Ferg
  • Turtle Points: 416
  • Male Posts: 577
  • Member since May '03
  • That was EASY!!
« Reply #2 on: Nov 18, 2003, 05:32:42 PM »
Good radiator - '83 Toyota diesel!!  Comes as a three core and fits '79-'88 as a drop in.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Nov 22, 2003, 07:43:04 AM »
 :driving:hey i like that hood light idea,  :thumbs:thats a deffinite done deal :beerchug:
gferris5 [OP]
  • Turtle Points: 7
« Reply #4 on: Dec 07, 2003, 01:21:38 AM »
yea! some feedback! I knew you guys would be as stoked as I am! the hood light is way sweet and that temp needle is stuck in the hanging limp down position!  Thanks for the feedback, I felt this board needed a little, if even a silly, posting.
98runner chevota
  • Turtle Points: -100
  • Male Posts: 361
  • Member since Dec '02
  • PoP pOp Fizz fIZZ oh it must be a BIRF. It is!!
    • PortlandBusinessGraphics.com
« Reply #5 on: Dec 09, 2003, 08:35:28 AM »
 :shocking: :shocking: :crazy:
The light deal sounds good but wouldng a light out of a 88-93ish chevy pu be better the one with the light that has a magnet and a reel cord connected so that you have a light that can go anywhere on the vehicle within i think it is 15 or so feet. It is a safety light for doing tire changes and things like that.
Mark :smack: :laugh: :bowdown:
« Last Edit: Dec 09, 2003, 08:44:11 AM by xxx 85 toy »
1998 4runner with 4.3 liter Chevy vortex/ turbo 400/ 205 tcase/ hi pinion 44 up front with 4.88 arbs front and rear/ rear is a turbo with 4.88s/ 63" Chevy's in rear with 5 in Chevy's in front/
gferris5 [OP]
  • Turtle Points: 7
« Reply #6 on: Dec 09, 2003, 07:36:35 PM »
Yeah for sure, my friend has one like that and I couldn't find one in all the junk yard, I just settled for what I could find...the magnet and retractable wire are wicked cool though.
Rock_Starr
  • Turtle Points: -31
  • Member since Feb '03
  • Suck,Squish,Bang,Blow
« Reply #7 on: Dec 13, 2003, 06:07:27 PM »
Good work. And nice dual lockers.
Free wisdom for all:
"Spend your beer money on yourself, sex with strangers is often weird and uncomfortable, marriage ruins everything, and oh yeah, Gatorade is delicious."
yotacrawler85
  • Turtle Points: 2
  • Member since Nov '03
  • east coast ROCKS!
« Reply #8 on: Dec 19, 2003, 11:54:32 AM »
i like the uder the hood light idea..... i went to the junkard to check it out and there are a few other vehicles that have the same type of switch
85 cab on a 87 sas frame with 6 inch lift, 15x10 wheels, 34-10.50 swampers, all pro high steer, shock hoops, dual diff guards, in cab roll cage, rancho 5000s, all poly bushings remote diff breathers front and rear recievers, welded rear(4:30's) 22re
Toyoballs
  • Turtle Points: -164
  • Member since Dec '03
  • The Slow and The Dangerous!
« Reply #9 on: Jan 06, 2004, 08:26:11 PM »
Late 80's Ford pickups have the retractable light bulb cord and gravity switch - but no magnent - ehhhh - make your wife hold it...
Just Grind It Down To Metric...
"MAKE IT OR BREAK IT"
Extreme Off-Road Club
gferris5 [OP]
  • Turtle Points: 7
« Reply #10 on: Jan 07, 2004, 11:30:00 PM »
if she hasn't stormed off already because her husband insists on driving crappy old trucks everywhere that strand you in the dark...(not personal experience-just a projection)
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #11 on: Jan 08, 2004, 01:04:01 PM »
Quote
:down: yeah right  :talkingn:
max
  • Member since Jan '04
« Reply #12 on: Jan 12, 2004, 06:02:22 PM »
WELL SPEAKING OF LIGHTS, In my 1st gen 89 4runner there is a socket to plug in a 9V light for fixing things on the trail thats very cool, however I am not the orginal owner as I was 5 years old when it was made haha.  Has anyone ever seen the light toyota supplied? I would love to buy an orignal, if any one wants a pick of the socket I will post it, its beside yota hood release, that would be in front of your left knee when your driving.
rocktoy74
  • Turtle Points: 213
  • I WANT FRONT DIG!
Re: Three things I'm stoked about modifying
« Reply #13 on: Jan 08, 2005, 06:31:29 AM »
Here Is a pic of the light Toyota supplied with the vehicle The ex has a fully loade 85 runer and It has this option and I found a factory light to go In the truck.
84' XTRA Cab, 22R, R151, Dual cases W/Marlin Crawler 23 Spline 4.70 Total Spline and 23 spline 2.28 Crawlbox, Alcans, Bilstein 5125's, HP 529, V6 529, HAD Shafts, FROR Full Floater, Old School AllPro Crossmember, Marlin Crawler High Steer, Marlin Crawler Bumpers and Sliders
4x4fiend
  • Turtle Points: 7
  • Male Posts: 55
  • Member since Apr '05
« Reply #14 on: Apr 18, 2005, 06:59:52 PM »
so thats what that plug is for eh (refering to rocktoy74's post). i got a light from princess auto, about 2x4" rectangle, think its for tractors or something. i dont know if anyones ever seen the old jeeps, had one that popped up next to the radiator but htat wehre i put mine, doesnt reach the entire bay directly but its bright enough to see all u need. it also has a swivel mount so it moves nicely.
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #15 on: Apr 18, 2005, 07:32:51 PM »
Good info about the under-hood light, I was about to hit the wreckng yard and was gonna look for one
Oh, and when I read step #3 I was laughing, nice :beer:
gferris5 [OP]
  • Turtle Points: 7
« Reply #16 on: Apr 21, 2005, 02:49:56 PM »
wow,  I can't believe this thread is still alive and well.  As an update--my underhood light is good, but the best thing has been that radiator--I drove down I-5 in the middle of the summer on the hottest day with the AC on and that needle didn't even get close to half-way.  The only draw back is that the heater does not get the cab as hot as with the old radiator.
BigMike--if you can find the Caravan or similar domestic vehicle with the magnetic/retractable light, that is the coolest and best one, it'll even reach down to your tires if you need it to.
Good luck
myyota
  • Turtle Points: -1
  • Male Posts: 120
  • Member since Nov '06
« Reply #17 on: May 02, 2008, 09:38:55 PM »
I just found a factory toyota under hood light in an 84 celica and bought it, i will be installing it in my 86 4Runner.
86 4Runner
Solid Axle Swap, 5'' Of Lift, 37x12.50-15 MTR Tires, 5 Speed Manual Swap, Inchworm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5''Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears and an ARB, Downey Header, Optima Battery, Trail Gear Sliders.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #18 on: May 02, 2008, 09:43:02 PM »
WOW! Another back from the dead thread. Cool find though! :thumbs:
Last post Dec 08, 2004, 10:23:21 PM
by newkid
Last post Jan 20, 2006, 01:55:58 PM
by Rocksurfer
Last post Jul 10, 2007, 09:50:54 AM
by Doof
Last post Oct 03, 2007, 12:44:38 PM
by hot_karl
Last post Jul 19, 2009, 08:37:50 PM
by V-Man
