Hello everybody !
I have just sold my 37" 1990 Hilux and purchased a 2000 Tacoma SR5 V6 Xcab. This is very special here in Norway since it have not been normally imported by Toyota.
Yesterday I tried on some different wheel combinations and fond out that 33x9,5 ob 8x15" White Spoke rims with ET-20 did rub. 235/85-16 on standard old Hilux rims 6x16 with RT0 did not rub, but was just about to rub.
ET0 means that the rim is just as wide outwards as inwards (backspacing in the area of 3,25), ET-20 means that senter of rim is 20 mm outwards. We normally do not use the Backspacing measurement here in Norway.
But - for lift kits I see that most companies deliver blocks or add-a-leaves for the rear doing a lift in the area of 2-2,5".
Up front I see various solutions with 1 part block, 2 parts block and even adjustable coilovers to get a lift in the area of 2-2,5"
Using longer shackles I will only gain a 1" lift in the rear and that is not enough if I lift the truck up front 2".
I do not want to use lift blocks so what is your opinion about the add-a-leveas ? Which supplier is to supposed to deliver the best product ?
Allpro Offroad do deliver a complete 3" rear kit with new leaf springs but do anybody know how this actually is working on road and with having larger paylodas on the truck ? I guess it will work very well off road, but I'm mostly concerned about payload and on road.
I also see that OME deliver complete new rear springs, any opinions about them ?
And for the front is those polybush spacers (for example from Daystar) a ok solution to lift the truck ?
Its mostly a on-road truck this one, but should be able to do "green and yellow" tracks offroad, included trips to Iceland with complete camping gear (maybe also a camper on the bed) for 2 persons and offroad driving in those remote mountain areas up there.
Looking forward to receive your advises !!
