2000 tacoma trd rear axle on a mini
Started by bjwest, April 22, 2006, 06:02:06 PM
bjwest
anyone ever swaped the whole e-locker axle. is there any write up what dose it take. have the axel have the truck need some advice.
sounds like a piece of cake man,  i have a 05 taco elocker in my mini housing,  i hear the taco housings are a little thinner tube  so you might want to watch how big you go with the meats
bjwest
thats what i thought.
my questions would be
how wide overall compared with 85 front
spring perch placment
do they make 5:29 gears for them
how easy is the e locker harnes to duplicate
is the pinion flange the same as mine
do i need difrent brake master cylander or porportioning valve.brakes
i think it has disc rears not sure need to check
i think im going to guset the whole thing to fix the thin wall problem
disc rears ??   sounds like a fj80 rear
either way,  what mods you have to do will be worth it,  as for the elocker wiring and switch  check out www.12voltguy.com
bjwest
no rear dics dont know why i thought that
sounds like wishful thinking to me :yupyup:
i bet the spring perches are the same
if not  just buy some and weld on at the right spot
bjwest
i think it will be easy enough. by my proublems usualy start when i think so i figured id just ask and see
josho
Quote from: bjwest on April 22, 2006, 06:45:44 PM
well, they are 60.5 WMS
you will need to change the spring perches
search under e-locker diagram on TTORA.COM
pinion flange should be larger and no to the proportioning valve, IMO
good luck!  holley
Rockdiver
I have heard that the axles and diff are great  but the housings are the weak link  Heard they break under abuse  tube by ubolts will crush if use impact on them
