one other thing is that the very front body mounts are different for sa and ifs trucks.
it really is not that hard to do a sas at all. with the right tools and all the parts it should not even take a day to do all of the front. I am 19 and have done 3 in the last year
definetly do the sas. i assisted on ToThe Floors truck doing the body swap, and did it to my 83 when i swapped frames. sas is a cake walk, if you have an idea of what your doing. next you asked about swapping engines, yes the harness unplugs, but the question is are they both carb and carb, or efi and efi. if not then its a whole new game
weld the front and hate life and be replacing cv's and other ifs crap, yet alone not being able to turn. just do the rear granted i dont reccomend it, i just had one break
I am building up my truck using an 85 pickup cab and bed, on a 86 4-runner frame. As far as I knew the only body mount i know that re different were the third set back, they need to be cut and moved back 5 3/4" to adapt the 85 cab. I was positive that th front mounts and the second set were the exact same. If they are not, i am in for a nice suprise.plus you have to either stick with th carbed 84 motor or swap the harness over from the 4-runner which is a huge pain. Ultimately I would say solid axle the runner, much easier.My shirts all F'ed up
I get to swap a body and drivetrain on to a new frame, and SAS it, so I really can't decide.Sam
well wont it last a while, i will dd this truck to school and stuff, it will only be wheeled almost every weekend. i wont be replacing ifs parts, i was thinkin when it breaks i sas, although you guys are really leaning toward an sas so i think thats what I'll end up doing. how well do tires hold up to welded rears with street use
Why are you doing all this work anyway...or did you cover that already, and i just missed it. Not my day I tell ya'.
I'm with yotaboy79 on this one. I have an 89 extra cab, 4.88's 31" BFG MT's and all I did was put shackles in the rear and torshen the front up. My truck does really well on the trials, although I do need a locker for the rear. I've learned to pick a good line with the IFS. You will be better off learning to wheel with the stock 86 runner then doing the solid axle later.
+1!I wheel my stock '86 everywhere with a minor lift and 31's, it has forces me to pick better lines and actually LEARN
Started by kyle_22r General 4WD Discussion
Started by 4cruzer Toyota Pickup/4Runner Tech 1979-95
Started by stihlmohawk Newbie Questions
Started by Mr.Kitt New Member Check-In!
Started by Rocksurfer Transfer Case/Drive Line
