Author Topic: l50 tranny problems.....????????  (Read 1644 times)
studentwheeler
  • Turtle Points: 121
  • Male Posts: 382
  • Member since Feb '06
« on: Feb 03, 2006, 06:14:28 PM »
hi there, just got an 82, anyway the tranny has been giving me problems, it doesnt want to shift into first once the truck has been driven for 15 min or so or until it gets hot, shifts perfectly fine when its cold, i have to shift through the gears before i put it in 1st when it gets hot and sometimes even after going though the gears it still doesnt want to go in,.......whats going on with it????
Re: l50 tranny problems.....????????
« Reply #1 on: Mar 14, 2006, 06:43:15 AM »
kinda sounds like a bent fork, what  weight of oil are you running in the tranny  and is it full?   you should have 80/90 wt  in it
if i dont get back with you email or pm me  :thumbs:
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #2 on: Mar 14, 2006, 08:18:17 PM »
Begin by checking the oil -- just like the boss said :thumbs:
Then check the seat and socket, I bet they are waisted or missing.
Next, it gets into $$
reklund5
  • Turtle Points: 286
  • Male Posts: 1,263
  • Member since Nov '03
  • I love my Marlin Crawler!
« Reply #3 on: Mar 14, 2006, 08:54:12 PM »
I hate to contradict Glen here...but you oughta use 75/90 in a transmission for smooth shifting.  80/90 is fine in warmer climates, but if it gets anywhere below freezing where you are, the 75/90 will shift much smoother when the trans is cold...
MY  :twocents:   :wave:
Ryan
studentwheeler [OP]
  • Male Posts: 382
« Reply #4 on: Mar 15, 2006, 12:51:08 AM »
thanks for all of the help guys, it turned out to be the master, i went ahead and replaced both the master and slave, shifts like a charm
« Reply #5 on: Mar 15, 2006, 06:49:11 AM »
Ryan
you're right Ryan,  i was thinking for my area :smack:
« Reply #6 on: Mar 15, 2006, 06:50:41 AM »
since his problem seems to be fixed i'm going to lock this topic  so he doesnt continue to get replies
:psss:  Marlin called me ... boss  :bowdown:
Last post Apr 06, 2006, 11:00:49 PM
by olemisstoy88
Last post Jun 10, 2006, 08:58:46 PM
by Marlin
Last post Apr 10, 2008, 09:01:44 PM
by theside00
Last post Jul 13, 2009, 05:40:37 PM
by blyle84
Last post Nov 11, 2017, 11:35:44 AM
by Daaanger1
