Author Topic: f150 leaf bushings  (Read 2705 times)
johnnygalt
  • Turtle Points: -129
  • Male Posts: 224
f150 leaf bushings
« on: Jan 27, 2006, 02:33:01 PM »
I recently installed a pair of F150 leafs in the rear of my 91 runner.  Adios coils!  But I noticed the sleeve/spacer in the stock eye bushings do not pivot.  So if I tighten the spring bolt down snug, compressing the spring hanger against the sleeve, the front of the spring won't pivot.  If I leave it loose, it the steel sleeve will wear against the side of teh steel spring hanger, plus it might back off.   :ack:
I'm not sure how it was stock, if Ford let the spring just pivot on the bolt, but ideally it would work like most, the sleeve is tight against the hanger and the spring pivots between the bushing and spacer.
What are the rest of you running that have F150's?
Thanks
tony
johnnygalt [OP]
  • Male Posts: 224
Re: f150 leaf bushings
« Reply #1 on: Jan 31, 2006, 05:32:11 PM »
Anyone?
« Reply #2 on: Mar 20, 2006, 07:47:51 PM »
drive that out with a BFH  and put some poly bushings in
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Annihilation Fabrication
« Reply #3 on: Mar 20, 2006, 07:55:46 PM »
the spring eyes arent big enough to do that and have any sort of twist
Do you need a Hammer?
johnnygalt [OP]
  • Male Posts: 224
« Reply #4 on: Mar 28, 2006, 09:38:46 PM »
So order poly bushings from Summit or is there another bushing OD that works?  What about Johnny Joints?
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #5 on: Mar 04, 2010, 02:12:09 PM »
Imk putting flex joints on the rear of f150. thats 18mm bolt?
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #6 on: Mar 04, 2010, 02:30:23 PM »
I used the stock F150 front bushing. I threw a bolt that fit in the hanger and called it good. The bolt isn't 18mm, so it is loose inthe hanger but tight in the bushing sleeve. Flexes fine. :dunno:
Last post Feb 22, 2005, 07:12:35 PM
by hossjs
Last post Oct 08, 2006, 07:53:20 AM
by Weldo
Last post Nov 05, 2009, 06:10:59 AM
by diggtbks
Last post Dec 29, 2011, 08:47:26 PM
by yotaneck13
Last post Apr 13, 2012, 06:52:54 AM
by 86yoter
