Author Topic: Wheel movement  (Read 2624 times)
crx-si
  • Turtle Points: -134
  • Member since Nov '05
Wheel movement
« on: Jan 15, 2006, 07:38:37 PM »
I have some play in the front wheels, i pull on the top of the wheel and it moven in and out a little what is the part called that i need, is it a bearing or a shim.
Its the same as if you had play in a ball joint.
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: Wheel movement
« Reply #1 on: Jan 15, 2006, 09:01:45 PM »
Most likely you need bearings, but not knowing what kind of truck your talking about it's tough to say.
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
Re: Wheel movement
« Reply #2 on: Jan 15, 2006, 10:12:54 PM »
If it is a straight axle it could be; wheel bearings, trinion bearings, loose nuckle studs, or loose hub parts.  Take it apart and find out the problem.
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
Re: Wheel movement
« Reply #3 on: Jan 15, 2006, 10:18:48 PM »
trunion bearing, replace it and re shim it
crx-si [OP]
Re: Wheel movement
« Reply #4 on: Jan 16, 2006, 11:19:45 AM »
Sorry it is a 85
GrenadedToy
  • Turtle Points: 49
  • Member since Jun '05
  • Maatt Daeemon
Re: Wheel movement
« Reply #5 on: Jan 16, 2006, 12:24:31 PM »
i just finsihed replacing my trunion bearings. its not a hard job its just kinda tedious. especially if you have a problem getting the cone washers off like me :thumbdown: but other wise just buy a rebuild kit from  :turtle:  and get to it! good luck :biggthumpup: this site is really helpful-http://www.birfield.com/~morgan/tech/axle/
crx-si [OP]
Re: Wheel movement
« Reply #6 on: Jan 16, 2006, 03:41:32 PM »
Ya thats it thanks, can you get the knuckle bearings any place other than the dealer.
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
Re: Wheel movement
« Reply #7 on: Jan 16, 2006, 06:34:48 PM »
marlin sells a compleat kit to rebuild your nuckles without the wheel bearings it runs $75 and with wheel bearings its like $145? its a quality kit every thing you need to do both sides :beerchug:
  • Male Posts: 9,757
Re: Wheel movement
« Reply #8 on: Jan 16, 2006, 07:29:41 PM »
You can try calling parts houses and see if they have em, which I would bet they would atleast be able to order them.
GrenadedToy
  • Turtle Points: 49
  • Maatt Daeemon
Re: Wheel movement
« Reply #9 on: Jan 16, 2006, 09:04:45 PM »
im pretty sure marlins kit, even with shipping is cheaper than it would be to buy the rebuild kit front a dealer. and if you buy the rebuild kit you can replace all those worn out gaskets :yesnod:  :thumbs:  i was originally gonna buy just the truinion bearings but it would be easier to buy the rebuild kit that way if you do find a bad gasket you have one you can replace it with. :biggthumpup:
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
Re: Wheel movement
« Reply #10 on: Jan 16, 2006, 09:53:42 PM »
plus wile your in there you might as well do it all
Last post Aug 21, 2006, 11:28:33 AM
by MiniSimp
Last post Nov 16, 2007, 10:34:52 PM
by Rocksurfer
Last post Jun 13, 2011, 05:48:03 PM
by Wermz84
Last post Aug 03, 2012, 09:14:39 PM
by 89 runner
Last post Aug 21, 2017, 09:52:53 AM
by schadenfreude
