Project -" Framed" Full widths and more power
Started by whiteman, November 18, 2005, 12:18:27 AM
Ramrod
you should really put another leaf in those packs for up front,  I had the exact same ones as your going to run and they were too soft.  I added one more stock rear leaf cut down and it was perfect.  Everything else looks great though :biggthumpup:
whiteman
Thanks BBW, I will take your advice.  I should be mounting them next weekend.   I have to wait to borrow my friends welder again.
Ramrod
whiteman
Yea we will see how i like the five leafs, if I do end up running a 4-link and coils I may stick with five leafs so I can hopfully have my suspension balanced.
If they are too soft i could look into air bump-stops or just adding another leaf :dunno:   I will just have to wait and see, I really am impressed with the flex your rears up front gave you, you truck flexes awsome.
whiteman
Heres some :pokinit: that went down too night.
I got my cross member platforms welded on, they fit great, and line right up with the cross member.
whiteman
Some of my welding, easy on the bashing, I'm a beginer. :hammerhead:
whiteman
Here is a brief idea what the cross member plates will look like the right side is not complete yet nore the left.  I will spend some more time tomorrow night cleaning them.
I close shop around 10pm during the week for the neighbors sake.  But when the week end comes there kept up all night :yupyup:
6.72:1
Is that plate just hanging there, or it that plate gusseted where we can't see it?
I am sure that it will hang on there anyway, but gusseting is always good!
I am sure I am not telling you anything new! Cool build up though. Makes me want to build myself one! Taking you design now...lol
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
mudadiction
Its looking good man just like you described it too me. You have some great progress you must want this thing done really bad.  Thats some good looking welds for a beginner are you using kevin's welder agian? Hey when I come over on the 17th I'm going to bring my ford over maybe we can go do some wheeling or something.  we'll see what happens.
Ford F-150 73' front end lights grill, 75' Engine, 79' axles and running gear tranny transfercase and cab, One dam good truck.
whiteman
Quote from: CRUSHEDTONKER on February 07, 2006, 01:30:52 AM
Yes, there is going to be gussets under the platform that is welded to the frame.  As of right now I have welded a small 1" bead at each end on the under side, but the frame is sitting so close to the ground, I would have o welder up side down, I am not that goo yet.  I will weld the under side once the front axle is in and I can get to it easier.  Thanks for looking out though.  :thumbs:
Quote from: mudadiction on February 07, 2006, 04:03:30 AM
Its looking good man just like you described it too me. You have some great progress you must want this thing done really bad. Thats some good looking welds for a beginner are you using Kevin's welder again? Hey when I come over on the 17th I'm going to bring my ford over maybe we can go do some wheeling or something. we'll see what happens.
Yea, it's coming along pretty good.  I am borrowing Kevins welder, actually his dads.  Hopfully I can have the front axle in before you come over.   :greengrin:
MiniSimp
Gusset that good, the inside of the frame is only 1/8" thick and bends easy.
whiteman
I was thinking about running two gussets under nieth of the platforms running down the frame; and then on the outer edges, have a gusset welded to the sie of the platform , running up the frame.   Does that sound clear.
MiniSimp
mudadiction
I'll be over next weekend you better get a move on it if you want to have the front axle in.  I guess you don't have that much to do before the front axle you have to finish your crossmember and fabricate some spring hangers.  right? then you'll be almost ready to set the cab on.
whiteman
Yea like that under nieth ____
                                   l   /      and like this on top   l       l    <-- Top
                                   l /            Platform  ____>   l____l
                                   l/                                        l    l
        l    l                 <--- Bottom
                l\
Side view   l_\___               It will be somthing like this, but more complex.
                l  /
                l/
MiniSimp
whiteman
Quote from: MiniSimp on February 07, 2006, 10:01:07 AM
Looks good. :thumbs:
Thanks Mini...
Damn it i cant wait till I get off work.  I need to fabricate, it's like an addiction now, I'm starting twitch and tweak out when I am not in the garage.
whiteman
I cleaned up the cross member, grounded edges down, and rounded corners.
Painted and ready for the holes to be drilled that I forgot about untill after I painted it :smack:
mudadiction
So you decided to paint something blue huh.  What other things do you think you are going to paint blue?
6.72:1
[email protected]
MiniSimp
You've tested to make sure that sits flush on the transfer case right?
Looks good!
whiteman
Yes, I suppose that I should take a pic.  I will see if I can get a pic this morning paint should be dry.
whiteman
Ok I got some pics of it in place with 1" of rubber between the cross member and mounting platforms.
It sits on perfect, with all bolt holes lined up. I was thinking of adding another 1/2" of rubber on the top with a small plate like 1/8" sandwiching it in between the rubber :dunno: ,  I think it would help absorb vibration and allow a slight bit more play.
I used dark blue rustole um poof paint.  It was the most close color I could find in a poof can to match the body color.
This things going to end up looking like a big  :stopit:  rainbow. :greengrin:
MiniSimp
With that much rubber in between plates make sure you use a Grade 8 fine thread bolt with either anti-sieze or locktite and torque it to the bolt specs. (I can get the torque specs for ya)
whiteman
Yes I was defiantly going to use Grade 8-  I was going to use four 1/2" grade-8 bolts 3 1/2" long, what would the specs be.
MiniSimp
119 foot pounds if you are using 20 Threads Per Inch.
whiteman
Sweet, now I just have to get a torque wrench.
mudadiction
Are you just going to use 2 bolts on each side or 4?
whiteman
MiniSimp
Quote from: whiteman on February 08, 2006, 09:05:31 AM
You should buy one, you will need it for almost everything on your truck.
They are only around $143 from White Cap.
