Front drive shaft?
Started by dentedfender, November 03, 2005, 03:54:07 PM
dentedfender
I was wondering if i could use my stock 85 front drive shaft cv part and then get a rear drive shaft cut it down then weld a long slip kit on it? and be able to use the cv joint?
85 4runner rears up front f-150s out back dual 2.28 cases 22re, rear discs, 5.29s, locked f/r, 38s....... list goes on and on
CRS
If your looking to build a rear driveshaft out of your front then all you have to do is have a driveline shop lengthen the front shaft and it will bolt right up in the rear.
If your loking ot make a long slip front shaft just cut the yokes off and make a square shaft its beefer and way cheaper then all that work you were thinikng
IN LOVING MEMORY OF JAKE. MY BEST FRIEND AND COPILOT
                  WITH ME FOR A MILLION DAYS
                         2-15-05  4-12-06
dentedfender
i would make a square shaft but i need something i can drive in 4wd high going 60 with out getting shaken to death
yotaboy79
ive had my square front up to 60 with no problems didnt notice any vibes it did make a some noise because of the slop in the tubing but that was it :beerchug:
lilbuddy
Quote from: yotaboy79 on November 03, 2005, 05:49:51 PM
Same. Only time it vibrated is when i let off the gas. At 55-60 its good. Little more then usual but thats it.
RIP Kyota.... you are the man
GET IT!!!
Shamb
.........why do you need to go 60 mph's in 4 wheel drive?  Not good...
dentedfender
do you need two front shafts for a square front? and 60 because i live in colorado and it snows alot so 4 wheel is nice on those slopy days
CRS
no you only need the one you got
                         2-15-05  4-12-06
Shamb
you can get square tube that fits nice and "snug" into one another, just cut the ends off and weld them to the tubing. Very simple and durable.
dentedfender
ill give it a try so for tubing its 2x2x1/4 reciver then regular 2x2 for the smaller  one?
Shamb
yea use a 2x2 1/4" for the outer portion and 1 3/4x1 3/4"  1/4" for the inner slip section.
Make sure it fits nice and somewhat tight.. obviously you dont want to jam it together but in the same sense you dont want slop because slop = death wobble.
The better the fit the happier you'll be when that front DL is spinning like mad.
dentedfender
for the slip part is that packed with grease or is it just dry?
Shamb
I wouldn't pack it with grease, just coat the inner slip section with some good sticky grease.
dentedfender
now im confused do i use 2x2x 1/4 and 1 3/4x1 3/4x1/4 or do i use 2.5x2.5x1/4 and 2x2x1/4 like minisimp did?
Shamb
either way will work. Think about it
You have 2.5 on your outer edge -1/4"  for each side (thickness)  and a 2" inner slip that'll fit nice and snug.
2.5 - .25 -.25 = 2
get it?
Or..  2 1/2" - 1/4" - 1/4" = 2" which will be your 2 x 2 in the middle.
Shamb
example.
my 1 min drawling  :D
dentedfender
ok thats all i need to know im hoping to have it done tomorrow thanks for the help guys
Shamb
post up your final product   :)
scyota
How much does the metal you need usually cost??
1993 4Runner SAS - SOLD
'01.5 Audi S4 2.7TT Stage 3
Shamb
we calculated our front shafts to cost around $35-38 completely finished.
Usually we buy it in 20 ft sticks and make a bunch though for spares or to sale.
dentedfender
front drive shaft is done the metal put me back 25 bucks.
