but but theres a red spot under that fender
looks like someone has a whole lot of time on that paint job. I like it, especially when someone does it right.. nice rig...Who ever painted it even pulled the doors off, look at the door bolts,,,, CLEAN. Also look at the bolts coming through the inner fender.. grade8.
we must crush zee knocksensor infadells
I have only one problem: knocksensor...... At the start,the warning light shines not . It comes on only after right gas give...what iss that??? adjusting valves?moment of ignition?
OK so we got the thick bacon... but RK can't find the salami... and Deans wife has the cheese...
hi my dears,the flashing light say: 41 and 52......the knock sensor and the automatic transmission.....but i have a manual transmission....so that problem is no problem.....but the temperature sensor is over...i need a new....have who one??? tomorrow i call my toyo dealer....that make fun, they knew nothing about 22re....
You can test the temperature sensor before you decide to replace it. If you do need to replace it, there should be a part number right on it, so the dealer can just order that part number.
thank you, good idea......i hope there is a number....
we ignore that code...and run out http://www.youtube.com/watch?v=93nXx7Lvk2kand it works...66cm without pressure out from tires
Ganz Gut!Wann kann ich vorbeikommen?Tschuess....
immer....einfach vorher Bescheid sagen yust give a call...befor
Gruess Gott! (I've been hanging around the Austrians too much...heehee!)
Started by 79coyotefrg Texas
Started by MiniSimp « 1 2 3 » Chit Chat Camp
Started by Aggie Trail Reports, Events, and Gatherings
Started by loubell Trail Reports, Events, and Gatherings
Started by Hammerhead Utah
