Author Topic: Need Help with 4.3  (Read 2891 times)
TrackVino
  • Turtle Points: 45
  • Male Posts: 1,038
  • Member since Oct '04
  • Rocking and Rollin with Marlin!!!
    • DCD Photo Studios
Need Help with 4.3
« on: Aug 22, 2005, 11:04:46 AM »
Heres the problem, took the 4runner out on a good solid run this weekend and had some minor problems.
The AC compress is no good on the Chevy 4.3L, but I kept it on because the serpentine belt uses it as another pulley.
I was wondering if anybody makes a replacement pulley that I can put in its place instead of using the compressor.
I don't want to put AC in this thing, its strictly for wheeling and don't see the point of putting it on. I'm also going to remove all the condenser stuff from the front so theres more air flow to keep the engine cool.
Any websites or have any of you seen this before?
Engine came from a 1988 Chevy s10 blazer, 2wd with the 700r4
What do you guys thing?
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
Re: Need Help with 4.3
« Reply #1 on: Aug 22, 2005, 12:33:44 PM »
takr the belt off, and run a peice of rope around all the pullys that you want, and go to napa with it. tell em you want a serpantine belt this long, and show em the rope, ive done it a few times, or see if they have one in stock for a blazer with out ac?
TrackVino [OP]
  • Turtle Points: 45
  • Male Posts: 1,038
    • DCD Photo Studios
« Reply #2 on: Aug 22, 2005, 02:11:42 PM »
Thought about that already, but the problem is that the tensioner is down and to the right of the AC compressor. It has to go that way to be able to adjust.
BUBBA
  • Turtle Points: 16
  • Male Posts: 1,138
  • Member since Mar '05
  • this sucks
« Reply #3 on: Aug 22, 2005, 02:19:42 PM »
Just take a trip down to the j/y and look around and see if you can find one with out a/c.The one's without it probably had a idler pulley there.
My budget beater
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
« Reply #4 on: Aug 22, 2005, 02:52:32 PM »
There is a part number for the correct bracket out there.  I know who would know what it is.  Ill get back to you tonight if all goes well.
FIREBALL
  • Turtle Points: 190
  • Hi Ho Marlin....u talkin to me
« Reply #5 on: Aug 22, 2005, 04:12:49 PM »
Or find an idler pulley from the wrecking yard that you can fab an easy braket for. You might still have to get a little shorter belt, but would be a cheap fix.
TrackVino [OP]
  • Turtle Points: 45
  • Male Posts: 1,038
    • DCD Photo Studios
« Reply #6 on: Aug 22, 2005, 04:31:39 PM »
Thanks WT, I would really appreciate it. I dont want to fab anything if I dont have to, just want to use the right thing if I can get it.
ToyDozer
  • Turtle Points: -3
  • Male Posts: 15
  • Member since May '05
« Reply #7 on: Aug 22, 2005, 05:13:02 PM »
My 4.3 had the bracket in place of the pile of R4 compressor. My donor was a 1992 C1500.. Should be a very common part in any decent junk yard..
Should look a little something like this.....
Jon Stensaa
ToyDozer@ACSAlaska.net
Accelerator : The stomped out hole in the floarboard!!!!
twin60s
  • Guest
  • Marlin Crawler
  • I used to Crawl. I still do, but I used to, too.
« Reply #8 on: Aug 22, 2005, 05:16:16 PM »
leave the pump on,and use it to pump tires,run air tools ect
ToyDozer
  • Turtle Points: -3
  • Male Posts: 15
« Reply #9 on: Aug 22, 2005, 05:21:16 PM »
Not with that pump... The R4 is marginal at best in regards to running air conditioning and completely inadequate in regards to OBA requirements!! I'm all for OBA but go york or better yet RV2 or go home!
Jon Stensaa
Jase
  • Turtle Points: -13
  • Male Posts: 147
  • Member since Sep '04
« Reply #10 on: Aug 22, 2005, 06:11:14 PM »
I use that AC pump for OBA and by the time I aired up two trucks and some guys 4 wheeler the thing was actually smoking (w/2gal. air tank) it did survive though.  I too would reccomend something different for OBA.
TrackVino [OP]
  • Turtle Points: 45
  • Male Posts: 1,038
    • DCD Photo Studios
« Reply #11 on: Aug 23, 2005, 01:04:01 AM »
Very cool, thanks for all the suggestions. I dont need an air compressor for air thoe, I have a power tank. And for the AC, I dont want to run AC, I think with this 4.3, I will remove all AC stuff, and allow more air flow thru the radiator.
I really like that picture ToyDozer, I didnt know they made a bracket like that. I will take a trip to the junk yard, and look at all chevys there. Im sure I can find one there.
 :biggthumpup:
« Reply #12 on: Aug 23, 2005, 01:58:08 AM »
What you need is called an idler pulley by GM.  part # 10118713  That came from a lead wrench at a GM dealership so Im sure its correct.
TrackVino [OP]
  • Turtle Points: 45
  • Male Posts: 1,038
    • DCD Photo Studios
« Reply #13 on: Aug 23, 2005, 09:19:32 AM »
Thanks WT, and by the way, I love your avitar.
310R
  • Male Posts: 18
  • Member since Nov '02
  • I love Marlin Crawler!
« Reply #14 on: Aug 23, 2005, 12:47:08 PM »
I have a 4.3 in my 84,I use the 1992 s-10 a/c delete pulley set up.IT came on work trucks or stripped down vehicles.But I do know it works,because it is on mine. :thumbs:
RIDE RED
310R
TrackVino [OP]
  • Turtle Points: 45
  • Male Posts: 1,038
    • DCD Photo Studios
« Reply #15 on: Aug 23, 2005, 03:08:37 PM »
Thanks for all the help, just need to go to a junk yard and find one now
ToyDozer
  • Turtle Points: -3
  • Male Posts: 15
« Reply #16 on: Aug 23, 2005, 09:18:24 PM »
 :biggthumpup:
Ya buddy, thats my trail spare that I carry along with a new tensioner with it's idler pulley and a few belts. You know, just in case I loose a compressor. The way I see its with a serpentine belt setup (which I love) its not even a matter of if but more a matter of when....
Jon Stensaa
