NEWBIE FROM SD CHECKING IN
Started by BUDDERS, July 24, 2005, 04:44:42 PM
BUDDERS
Just bought a '85 extra cab with all the goodies - even has power windows!  Now the bad news: the headgasket blew the day after I bought it.  I tore the head off while just hoping to replace the headgasket and do a half-ass repair and found #2 cylinder wall all scored up and the cylinders already had .075 overbored pistons.  So my buddy told me about this site and Big Mikes conversion.  I ended up buying a 3rz from a '04 taco prerunner with ecu/manual trans bellhousing/wiring harnesses/exhaust all the way to the cat and many other parts for $1500.  The best part is this motor looks like the miles are so low that the first oil change hadn't been done yet.  Right now, I have the new motor installed and bolted up to trans with new fabbed up motor mounts.  Hopefully this next week I can re-route the fuel lines and filter so I can have the local exhaust shop do their thing.  Then it will be towed home for the fun of wiring this motor.  Oh, I forgot to mention, I work for a Toyota dealership, so I'm printing out all the wiring diagrams I need via their TIS computer setup.  My intent is to build this truck into a mild trail truck/desert toy.  I bought it to haul my quad to the desert and to scare the crap out of my niece with while I'm out there.  I will definitely need some suggestions setting up the suspension - once I get it running of course.
4DEES
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
No Power
Sounds like a ton-o-work :yesnod:
Anyways good luck on the build-up :thumbs:
Oh yeah and  :welcome: to the board
Roll me back over !!!
mudmaster
 :welcome: to the board and sorry but someone had to do it :worthless:
Time to go wheelin!
oddball
toybuilt
1983 Toyota Turned Chevy
BobJ
 :welcome:  I'm guessing that's .075mm oversize, or can they be bored out to .075"???
BUDDERS
Thanks for the welcome guys!  Yeah, I know that I need some pics.  I've lost my download cable for my digital camera and need to make a trip to radio shack for a new one.  As soon as I do, there will be some pics for ya.
over_rev
Are you making a stand alone harness for the 3rz?Im contimplating 3RZ or go too 7MGE :hammerhead:
Pak It In Pack It Out!!
flourman
 :welcome: from another newb on here!!!
Doin' it FULLSIZE style!
BUDDERS
Hey Mr. Over Rev,
As of right now, I have only been staring at wiring diagrams.  I have the feeling that I will have to change the wiring harness to match a 2wd manual trans 2rz - should be easy, but time consuming.  I'm really hoping that I can use the ecu that came with this motor, but don't think this will work since it's for a 2004 prerunner auto trans and will probably give me a Check engine light for a number of trans codes.  Sure, I can get it to run, but in CA, we can't have a check engine light and pass smog.  It also might give me codes for no electronic speed sensor.  I'm going to use the original charging system with the new Taco alternator.  I just changed the regulator on the back of it to the old style 22re plug and reamed out the hole a bit in the cover so the plug would fit right.
BUDDERS
Here's some pics in the mean time.
BUDDERS
and a few more
Lady Di
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
dragr1
1985 4Runner, all the normal stuff
2007 Toyota Tacoma CC TRD 4x4
2000 Suburban 2500 4x4
2002 Lexus IS300
1991 Allegro (Ole Krusty) Motorhome
BUDDERS
The exhast turned out real nice.  Right now I'm tearing out the interior and I can't believe how many things are held together by wood screws.  Should have the new seats and carpet Scotch Brited by tonight.
bluerunner
Ted Striker: Surely you can't be serious.
Rumack: I am serious, and don't call me Shirley.
