lets see those pics of the crossmember and d-lines that you promised. Im curious to see. You need to take that thing out to the salt flats and tach it out. I see it now...Toyota madman wrecks 4x4 truck at 240mph! Sweeeet.
How is it dealing with the second tranny worth of gears??
Nice setup. What is your crawl ratio with reverse/reverse/low? And how did you mate them?
I want to do it with an R150 next All I have to do is use a coupler like the one for the 4cyl t-case to v-6 tranny.
I havn't crunched the numbers.. but wouldn't it have just been easier to get an adapter and go dual t-cases? I understand your reasoning with having more gear selection but geez, with Duals you've got 15 forward gear. That seemed like more then enough for me... I definently give your prop's for doing something off the wall!Did you build your own D-shafts or have them built? I bet custom D-shafts wouldn't be very cheap! lolCan I see pic's of In-Cab to see where your shifters are located?
that could be cool
u taken it on highway speeds yet? kinda curious how ur gas mileage would be as well as ur rpm's
How does the clutching work? 1 clutch for 2 trannys? Or 2 clutches?
Started by 85sr5 New Member Check-In!
Started by John H New Member Check-In!
Started by Bagged71 New Member Check-In!
Started by TheKid New Member Check-In!
Started by Krylon New Member Check-In!
