Just check'n in!
Started by Krylon, February 25, 2004, 12:29:19 PM
Krylon
Hello all.
Check'n in to say hello!  I have a 91 Yota p/u..  Stock for now, but the 22re is out and I am rebuilding it.... Hopefully I will have it doen soon so I can start on other things like an SAS swap, and get some Marlin parts on it etc.
:biggthumpup:
Mike
Red_Runner
sounds good i blew my 22RE I dont have the $$ to fix it right now so its just sittin tell i get it. Well lets see some pics
84runner
Welcome to the board! So are you doing any mods to the motor while it's out?
Krylon
Red_Runner - Mine had a broken timing chain guide and coolant leaked into the oil pan.  So while I had the front off I pulled the head to redo it.  Then pulled the bottom end from the truck and may redo it also since I have it out.   :biggthumpup:  All I have are a couple driveway shots from when I borugh it home.  I'll post em, but dont laugh!   :disturbed:
84runner - So far not really...  I just got a reman head with an "RV" cam...  Probably just keep it pretty stock...
Future plans for da Yota - 33's or 35's, SAS, Canback(already got rid of that crappy cap that in the pics), new clutch, tranny rebuild, etc....
Mike
Red_Runner
sounds good lets me know when you plan to do the SAS I have a compleat front end hub to hub so let me know
Krylon
Quote from: Red_Runner on February 26, 2004, 07:11:11 PM
Where are you located?
Mike
84runner
Nice truck Krylon! That axle is located near sacramento
Krylon
Thanks.  It's bone stock now with the 22re pulled out for a rebuild.  Origianlly it had a timing chain guide failure.
That axles a little far.  I know where there is one around here(about 60 miles away) for $150..  :)  But thanks!!!
Mike
ToyotaMax
Welcome Krylon! Have you checked out LC Engineering? They may have a few things you wanna "throw" in that 22RE. I got their Master Rebuild Kit and so far my four popper runs great (It has 294,000 miles on it!!!) Also, what SAS kit are you gonna use?
85 P/U, 5.29's, ARB's, 5" Skyjacker front w/ shackle, 5" Chevy rear w/ shackle+buggy,in cab cage, Ford shock hoops etc. I WANT CROSSOVER!!!
Krylon
Yes, I have been over to LC E...  So far I have everything for except new rockers/shafts and the bottom end done.  I should have the whole bottom end apart this weekend and then I'll take the block to get cleaned, checked and redone...  Then figure out what pistons, rings and bearings I will use.  I am kinda leaning toward KB Hyperu pistons just cause I know they're a good quality(have them in my 383 stroker).....
On the SAS.  I will probably build my own front crossmember unless I get lazy(which I do often)...  If I buy parts, I have been looking at them all - Marlin, All-pro, Sky, etc....  The crossmember doesn't look hard to make...  I wanna get the axle and probably the springs(possibly AP 3") before I start on that...
Mike
TacoRunner
Newbie.  Yup thats me.  Well lets see, I live in North Hills Ca. and I drive a 85 Runner with a Tacoma 2.7L swaped in. Currently running a W56 with a Marlin double case and 5.29's in the diff. I've got a detroit in the back, and right now my front is open. I plan on putting a tacoma rear axle in the back and a FJ80 frontend in the front some time in the future.
www.4WHEELUNDERGROUND.com
[email protected]
84runner
hey TacoRunner sounds pretty good. you should start your own post so everyone can get to know you
