Check out my new tranny!
Started by UNBREAKABLE, July 24, 2005, 10:35:25 AM
UNBREAKABLE
Dual w-56's! Test run @ Paragon July 29-31!
That's how I roll
CTENG in KS
unclejpl4x4
 :headscratch: and you'll be shifting into 4wd how?
unclejpl4x4
so how fast  do you think he can go  in 5th & 5th? :driving:  :laugh:
I am shore  he has a well thot out plan  and a reason  for  this very werd set up    I wish  he  posted a storie  to go with the pics :psss:
decyfer
what the deuce. so i understand the gearing down aspect of it but when you are on the highway how would that work. would you have to double :pokinit:. or just leave the back tranny in say fith and then shift through the front. what the crap. i'm confussing myself
is it bad when you unplug the power wire from your stereo and it still plays
decyfer
Quote from: Rocksurfer on July 24, 2005, 11:20:14 AM
hes going to have to reach into the back seat to shift. thats if he has a runner. imagine it in a pick up. getting out and reaching into the bead to shift. ha
lilbuddy
#7
Quote from: decyfer on July 24, 2005, 11:43:25 AM
He could just put the second tranny in 4th gear (1:1) and use the front tranny to shift around town and such
A guy on pirate did something somewhat similar... I think a 5 speed to a 3 speed to a single 2.57 chain drive case.
RIP Kyota.... you are the man
GET IT!!!
decyfer
i guess you could put the second tranny in neutral too.
holy crap would that be some serious low range. i have 4.1 gears with a granny gear that is 5.7 to one and its almost too low for me. i can only image dual tranny plus triple case. insane
freds40
#9
On the road, I'd say leave the front tranny in 4th (1:1) and shift the rear tranny. I would think there would be less ware in the system that way. The idea of being able to do it is cool but the fact that toy trannies gearing is pretty high in first gear doesn't make it a viable solution in my mind. Tons of gears to choose from is cool but really you can get more overall gearing out of triple cases and still be shorter.
I've seen a few people do dual trannies using sm465s. That would be a cool setup because you can run a bulletproof 205 behind it and even with the 1.92:1 gear in the 205, the 6.55:1 gears in the trannnies would still put you at or above 350:1.
"between projects"
freds40
Quote from: decyfer on July 24, 2005, 01:24:47 PM
A single tranny with dual cases with a 4.7 is going to be lower than dual trannies and a single 2.28.
"between projects"
CTENG in KS
I can't wait to see the rear shaft and the shifter setup...might be cool though :dunno:
4DEES
holy sheep :pokinit::shocking: .  UNBREAKABLE, please explain  :beerchug:
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
lilbuddy
GET IT!!!
mudmaster
Time to go wheelin!
UNBREAKABLE
#15
No joke. Dual W-56's Clocked up, my rear d-shaft is around 34" long (not too bad) front is 50" long.
The reason why,......why not. No need for regearing axles(just put one of them into 3rd gear for road driving)
50 Forward gears! Gear selection is unreal! The rear shifter comes up roughly where the seatbelt bolts are. I could build linkage to move it up but this rig is a budget build and I'm stretched on time.
That's how I roll
Duffil
damn, man...kinda redefines the spotter/copilot job, doesn't it..."mike, put er in first!"
what is the overall legth on that thing?  and all you need is a couple of Heims and some tubing to move the shifters forward...
UNBREAKABLE
overall length is 59"....my rigs are all x-cab's, longbeds, or 2nd gen 4runners so I have the wheel base to do crazy things like this
That's how I roll
UNBREAKABLE
I painted it white just to be funny.
That's how I roll
Duffil
what are you gonna run for a crossmember...
UNBREAKABLE
I am making my rear using some thick 5/16 diamond plate and a factory rubber mount. I have a second mount in the adapter plate (if you look in the pic you can see the mounting holes
That's how I roll
mudmaster
You are doing this because you can?
Time to go wheelin!
Duffil
yeah, I saw those, but wasn't sure why they were there.
Duffil
Quote from: mudmaster on July 24, 2005, 07:49:03 PM
not quite a fair comparison, but people thought the same thing about dual cases once...I'm just glad to see someone have the balls to do it with w56s!  :screwy:
UNBREAKABLE
That's how I roll
mudmaster
Quote from: Duffil on July 24, 2005, 07:50:39 PM
So true
Time to go wheelin!
UNBREAKABLE
I want to do it with an R150 next All I have to do is use a coupler like the one for the 4cyl t-case to v-6 tranny.
That's how I roll
UNBREAKABLE
That's how I roll
UNBREAKABLE
I have also been wondering about doing something with an automatic. I have 3 here at the house along with an R150 or 2 and a few assorted w-series and L-series.
That's how I roll
UNBREAKABLE
I will have more pics tomorrow. I nearly finished the rear x-member today. I will finish it tomorrow along with the d-shafts and the front x-member.
That's how I roll
