toy rears in front
Started by crawlerdan, July 14, 2005, 07:46:13 PM
crawlerdan
if i add my stock rears, 3 leaf w/overload, to the front of my ifs rig when i sas, how high will it lift it/ anyone running these with no addaleaf? pics are always good!
MiniSimp
3 leaf rears in the front will be inverted with negative lift.
You need to add more leaves, 6-7 is about right.
crawlerdan
you think it would be lower than ifs?
MiniSimp
Ramrod
I have a friend running completly stock rear springs up front on an 83.  He loves them the overload leaf seems to keep them from going negative at ride height
crawlerdan
good stuff minisimp, ill add two leaves or so, i dont wnt alot of lift, 3 or 4 maybe
MiniSimp
Quote from: bigbluewillys on July 14, 2005, 08:56:53 PM
83 rear springs have 3" more arch than 84+ rear springs. Check out Roger Brown's site.
http://www.4crawler.com/4x4/4R_suspension-III.shtml#CustomSprings
83 rear main leaf on top, 85 rear main leaf on bottom
crawlerdan
MiniSimp
Here is what I made:
Quote from: MiniSimp on February 27, 2005, 07:40:36 PM
Built my spring pack for my "Rears up front"
They should be nice compared to my currently reversed springs.
Opened up the clamps. Need bushings.
Specs:
1st leaf: 85 1st leaf
2nd leaf: 85 2nd leaf
3rd leaf: 85 3rd leaf
4th leaf: 85 1st leaf cut down
5th leaf: 85 3rd leaf cut down
6th leaf: AAL
MiniSimp
crawlerdan
i have access to 67 bronco rears, good adda leafs?
MiniSimp
Quote from: crawlerdan on July 14, 2005, 09:26:53 PM
Depends on spring rate, arch, width.
crawlerdan
stock rate and low arch 2.5 wide
MiniSimp
Try them out, mix and match, find out what you are happy with.
That's the best way to find out.
crawlerdan
i agree, i just have no patience... :headshake:
MiniSimp
Quote from: crawlerdan on July 14, 2005, 09:36:37 PM
:funny: Me either, which is ironic since my build is going so slow. :snare:
crawlerdan
well at least youve started, all i have is the cases, dual ultimate with twin sticks, all hand made by marlin....yummy :yesnod:
MiniSimp
Quote from: crawlerdan on July 14, 2005, 09:39:01 PMall i have is the cases, dual ultimate with twin sticks, all hand made by marlin
Life is rough! :tantrum:
:laugh:
crawlerdan
ya, at least i got my cases :love:  :love:
mr4x42u
you will have axle wrap so bad with just 3 leafs that under flex and load it will bust your u-joint from putting the yolk to max and it will bottom out..even with the over load..most of the time this is only a problem going up hill when the weight is off the springs,,,it can get real ugly upfront with only 3 leafs..
lilbuddy
Quote from: MiniSimp on July 14, 2005, 07:52:08 PM
I have 5 in mine and it gave me almost 4 inches of lift
RIP Kyota.... you are the man
GET IT!!!
dirtyskivies
ditch the overload, its a rock anchor
add 3 leaves you cut to fit below the 3 'rear' main leafs(no overload). the springs you add can be 6-7mm leafs near 2.5'' wide. keep all the spring clamps and even weld something across the top to keep them together...
2002 trd v6 tacoma
1986 4runner type thing
1998 ktm supermoto
Quote from: dirtyskivies on July 15, 2005, 10:49:06 AM
Make sure you don't just toss the load leaf and not support the main pack, if you don't they'll bend and possible break. Always have a load leaf to a pack that requires one.
MiniSimp
 :bull crap:
Count how many people are using an overload leaf for their front springs (rears up front) in this thread: http://www.pirate4x4.com/forum/showthread.php?t=265669
Quote from: MiniSimp on July 15, 2005, 03:07:24 PM
:bull crap:
How about 0, but we wouldn't want a misinformed MCBB member to be the first. :laugh:
dirtyskivies
Quote from: Rocksurfer on July 15, 2005, 02:50:19 PM
huh?
2002 trd v6 tacoma
1998 ktm supermoto
