Gear Oil coming from the engine compartment??
Started by 90slvpup, May 07, 2005, 06:17:07 AM
90slvpup
Woke up this morning to see that there was gear oil all over in my engine compartment it looks like it is coming fron my breather hose which is about 4 ft long, is that even poossible for gear oil to get pushed up the breather hose??
have you been in deep water,  if so  go drain , flush, and refill all your gear boxes,  the water is pushing it out
90slvpup
havent been in deep water at all, the only thing i have done is light trail stuff with some hills.  It doesnt make sense why it would push fluid out that long of a hose when i havent even gone underwater
90slvpup
I havent noticed anything wrong with the diff. It was just barely installed last week, my guess is they had it overfilled and the oil expanded enough to come out the tube. but does anyone else have any ideas?? it has an ARB in it could that have anything to do with it??
I usually get fluild flowing out of my overflow tube if I travel at hi speeds and the hubs are locked or when I get lazy and don't disconnect my rear driveshaft when I flat tow.
guywithuglyyota
Mine did this once, but it was contaminated with water, I also had a hub that didnt unlock so I think it churned things up. If you figure it out let us know
Prismo
I have had this happen when I was running at high speeds on hot days during the summer.
Bloomcounty
maybey it's to full ! have you added oil lately ?
WileEToyote
Quote from: 90slvpup on May 08, 2005, 09:09:28 PMit has an ARB in it could that have anything to do with it??
Seals in the ARB could go, and that would pressurize the diff and push oil up the breather.  You would probably also notice some lag in it locking up.  When my rear ARB did this it usually wouldn't lock til I'd rolled around a few miles and heated up the diff to a running temp.
~Adam
96 T100, Dana44, lockers and stuff
75 FJ40, stock for the moment
b_ripper8
I've had that heppen when driving with the front hubs locked over 55MPH so beware of that.
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
90slvpup
Well I talked to a couple of places here are their results:
1. With the ARB and my diff tilted upward slightly it changes the way the oil is thrown covers the breather hole, creates a positive pressure and syphons of my oil. to slve add another breather
2. The speed issue if i go over 55mph in 4 wheel drive then i get squirts
3. the ARB is leaking and pressurizes my diff.
I will have to take it out and figure which one it is. thanks for the help guys!
Mason
