Author Topic: lock rite install  (Read 5110 times)
hawaii500_1999
  • Turtle Points: -7
  • Member since Jun '02
  • Watch this!!!!!
lock rite install
« on: Aug 20, 2002, 04:09:31 AM »
i got the lock rite some time ago.  and finally got a chance to work on the truck.  i pulled the third on Sunday and set it on the bench to work on later.  (in laws came over)
this is the first time i have done any work to a third member besides pull it out and bring it to the guy who charges me $ to work on it, and since there is no set up required if you do it properly with a lock rite i thought it was a perfect first time candidate.
let me just say that it went so fast that i spent about the same amount of time inspecting it.  if you're thinking about getting a locker but can't afford paying for a gear guy to build it i highly recommend it.  it was only about $250 too.
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
hawaii500_1999 [OP]
  • Turtle Points: -7
  • Watch this!!!!!
Re: lock rite install
« Reply #1 on: Aug 20, 2002, 04:16:57 AM »
so the first step was mark everything.  i used a center punch for everything, except for the ring gear and the bearing outer races.  i had to use a grinder and put a very small grind mark on them.
i marked the ring gear and carrier, the adjusters on the sides, and the bearing races.  i marked them so that i would know exactley how they came out, with left side to right side included.
easy enough.
(the bearing race was marked after the bearing caps where taken off of course)
hawaii500_1999 [OP]
  • Turtle Points: -7
  • Watch this!!!!!
« Reply #2 on: Aug 20, 2002, 04:19:13 AM »
:.order:
hawaii500_1999 [OP]
  • Turtle Points: -7
  • Watch this!!!!!
« Reply #3 on: Aug 20, 2002, 04:26:27 AM »
then i removed the bearing caps, bearing races, and carrier.  pulled the ring gear off.  with a long punch i hammered the smaller pin out of the center shaft so that it can be removed.  i removed it then the spider gears.  the larger spider gear thrust washers need to be reused.  then i cleaned everything in kerosene.
« Last Edit: Dec 31, 1969, 04:00:08 PM by -1 »
Brandon
  • Hawk
  • Turtle Points: 193
  • I believe in Life before Death
    • www.RiverCityRockCrawlers.com
« Reply #4 on: Aug 20, 2002, 04:30:38 AM »
the right kind of punch does wonders for that pin, tough otherwise!
Brandon Miller
RCRC, Sacramento, CA
hawaii500_1999 [OP]
  • Turtle Points: -7
  • Watch this!!!!!
« Reply #5 on: Aug 20, 2002, 04:31:34 AM »
next i greased the teeth in the couplings and put some grease in the holes on the ends and the thrust washers.  also placed four shear pins in their holes  and the spacers.  the instructions say something about the spacers not being symetrical on some vertions but this vertion (the 82 toy rear 8")  they were symetrical.
hawaii500_1999 [OP]
  • Turtle Points: -7
  • Watch this!!!!!
« Reply #6 on: Aug 20, 2002, 04:39:10 AM »
Placing the assembly in is a snap.  you just put them in the correct orientation then slide the pins from one side to the other then push in the springs.  after that slide the shaft through the carrier and assembley and push the locking dowel pin back in.
to tell you the truth i was expecting something more.
after that just assemble everything using the markings i made and i'm done.
just for the record:  i looked at the bench when i was done and there were only two empty  :beer:.
hawaii500_1999 [OP]
  • Turtle Points: -7
  • Watch this!!!!!
« Reply #7 on: Aug 20, 2002, 04:42:19 AM »
now it's back to the truck.   i need to pull the front third, put this one in, (check the birf's,) and work on installing a detroit locker for the rear. :.order:
but what do i do with the spider gears now?  maybe send them back in the lock rite box so they recycle them into more lockers. :greengrin:
  • Administrator
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #8 on: Aug 21, 2002, 03:24:42 PM »
Thanks for all the info ;D
Last post Mar 19, 2007, 01:29:08 PM
by TexJeff87
Last post Jan 20, 2008, 07:10:22 PM
by mayberry
Last post Aug 20, 2008, 08:06:51 PM
by matth_85
Last post Jun 01, 2009, 03:13:10 PM
by Volcom
Last post Feb 28, 2010, 10:02:01 PM
by possume22
