It's been about 30 days since you first posted on this thread. The "no start" and now start,run, then no start again is better than a Sherlock Holmes mystery. My curiosity is bugging the heck out of me. Gnarls.
AW geesh, this is taking way too much time and effort. It's gotta be something really simple. Simple is the hardest to fix.
Thank you for the update even though it sucks! Is the ignitor a TOYOTA factory type?Are the spark plug wires, including coil to disty, WIRE CORE?Gnarls.
Wow…Does GM make an ignitor specifically for a 22R? Or is that GM ignitor manually installed in place of the Toyota factory ignitor?If the engine was running fine when you shut it off, and it sat unmolested, out of any harsh weather for 1 week, the likelihood of a fuel or carb issue is not good.With temperature changes, electrical components (copper, solder, iron, plastic, rubber, etc.) can be affected by expansion and contraction, right?If the starter adequately spins the engine, it needs fuel and spark to start and run, right?.If the ignition module, disty, coil, plug wires, and spark plugs are good, with the plugs pulled, you should get a bright blue spark in the open air at the spark plug gap while grounding it to the engine and spinning the engine with the starter, right?I see there are aftermarket ignitors like…https://www.amazon.com/NewYall-Ignition-Control-Igniter-Assembly/dp/B09MFJZF3Q/ref=sr_1_1?crid=YZD6BYJWSOL4&keywords=22R+ignitor&qid=1691843386&sprefix=22r+ignitor%2Caps%2C141&sr=8-1but has a bad rating on Amazon. The one on RockAuto (Standard Motor Products) looks like the same thing but sells for $352.79!! But comes with a 5-year warranty.The reason I asked about the spark plug wires, is because I switched from carbon core to solid wire core spark plug wires many years ago. I discovered a brand new set of wires were bad. The carbon core was defective and caused too much resistance and did not conduct the 25K volts to the spark plug. The carbon core wires are good because they reduce the static (EMI) in the radio. Over time and changing spark plugs, pulling, and bending the carbon core, the carbon core breaks, causing a high resistance and weak or no spark.An ohm meter will quickly check for bad spark plug wires.As I mentioned, my gut feeling is that it’s an electrical issue, and like sirdeuce said, probably something “simple”…. an intermittent connection?Gnarls.
It's been about 45 days. I'm very curious to learn about what caused your "no-start" condition. There may be more chapters to this mystery novel, but I'd really like to cheat and sneak to the epilogue. Gnarls.
.... I'm not quite sure as I replaced that along with everything else in the ignition system.
I got a call from them this past Friday. They said the ignition module is not giving the right resistance and they suspect that is the cause of the issues. I'm not quite sure as I replaced that along with everything else in the ignition system. Anyways, they want to get a Toyota ignitor and wire that in to eliminate the GM ignition and universal coil. Either way, I can not believe it's been this long regardless.
The last I heard is, they put a Toyota ignitor on and it's starting up just fine.
I'd say look at the distributor innards. But wires can be an issue, probably a break inside the insulation AT a wire terminal. Also. check and rechack the grounds. MOst of the EFI Yotas I've come across have a ground that is on a position to be easily missed. Just when you thnk it's safe to go back in the water........
They told me they've tried so many things and are stumped.
Maybe this would be more fun
Wow!!! This mystery really sucks. I’m not surprised at the shop’s inability to find the problem.Back some years ago on my first 1986 22RE, I had an Autometer ammeter gauge on the dash and it showed a 60 amp charge after starting the engine and it stayed at 60.I knew something was wrong and it indicated the alternator was over charging for some reason.I checked everything I could think of, cleaned the battery cable and ground wires, checked the battery with a hydrometer, and the alternator and battery were showing normal voltages. Near where I worked there was an Automotive Electric shop. I stopped in and 3 guys spent 1 hour trying to figure out the over-charge on the ammeter.They finally gave up and said it’s the ammeter. I knew it wasn’t the ammeter. I drove home and figured it had to be some connection and most likely in the battery cables.So decided to put new battery cables on. As I removed the positive cable the bolt broke off of the lead that was molded around the head of the bolt where the cable attached and exposed a pocket of corrosion.That corrosion was just enough to create too much resistance and making the alternator put out more voltage as though the battery needed charging.Gnarls.
Started by toyotaboy General 4WD Discussion
Started by traveler727 Engine
Started by mtntoy Engine
