How about clocking the rotor, drill and tap.
id use factory driveshaft bolts from toyota. ive used some metric bolts/bolts from the hardware store but they come loose while the factory stuff stays tight. of course keep some as backup fer trail fixes.RUGER
There's a sh1t ton of stuff that is not recommended. I don't see an issue drilling it and putting a nut behind it. The rotor is still held in place.
My AP one was just a hole through the rotor with bolts and nuts they supplied with the kit.
https://belmetric.com/m10x1-0-extra-fine-din-960-961-hex-bolts-10-9/
The head on them is 17mm so the head will interfere with the CV joint yet alone be able to get a socket around it.
I always had to use two wrenches. Can you get away with a smaller head or drill it to standard?
A smaller head would work but finding a specialty bolt is going to be the hard part. If I’m drilling it out I’ll just use the bolts that came with the Tom Woods shaft. I have a some 30mm and 40mm long socket heads coming. Hoping I can get a bite on them and torque them down. We shall see!
Started by wrenchtech Engine
Started by 854x4 Parts For Sale
Started by rlwjaw General 4WD Discussion
Started by KYOTA Project Research and Build-Ups
Started by TRHS1980 Toyota Pickup/4Runner Tech 1979-95
