Author Topic: Manual trans/2wd behind (formerly) 4wd 3rz?  (Read 2365 times)
woytovich
  • Member since Aug '07
« on: Mar 18, 2021, 12:02:28 PM »
I'm looking for swap options for my 1966 Toyota Stout pick-up. I want to stay all Toyota, 2wd and manual transmission. 3rz trucks are pretty common but all those I'm seeing are autos and/or 4wd. Are there options to use a 3rz from a 4wd rig to a 2wd manual transmission?
Thanks,
mark
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
Re: Manual trans/2wd behind (formerly) 4wd 3rz?
« Reply #1 on: Mar 18, 2021, 12:45:35 PM »
2wd 98 4runner 5 speed. Has the 3rz..
woytovich [OP]
« Reply #2 on: Mar 18, 2021, 12:53:29 PM »
Sounds like a quest for the elusive unicorn hen's teeth... ;-)
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,145
  • Member since Sep '08
« Reply #3 on: Mar 18, 2021, 01:30:18 PM »
2rz would be a nice engine for a 2wd Stout. They are cheaper and easier to find.
woytovich [OP]
« Reply #4 on: Mar 18, 2021, 01:53:10 PM »
Are there any options for using an engine from a front wheel drive Toyota car adapted to some transmission for RWD? There are plenty of old cars out there for cheap.
sirdeuce
  • Turtle Points: 1293
  • Male Posts: 537
  • Member since Sep '06
  • One shot, one kill.
« Reply #5 on: Mar 20, 2021, 10:17:02 PM »
4AGE or 7AFE with a RWD corolla trans or W series trans with an adapter bellhousing. Beams 3SGE or second gen MR2 3SGTE with an Altezza 6 speed trans. 5SFE from a Camry or MR2 with an Altezza trans. Or if you want to do the legwork an 18RG or 2TG or 3TG-TEU would be an awesome swap. The 18RG would pretty much drop in and the dual carbs sound great! Drop in a Corolla 3TC and put a 'Hemi' badge on your Stout. If a V8 would be an option look at the 3-5V,  2.5 -3 liter V8 with a hemi combustion chamber. still Toyota and absolutely classic. All Toyota Hemi V8 Toyota Stout! Hmmmmm.
woytovich [OP]
« Reply #6 on: Mar 21, 2021, 08:39:12 AM »
Thanks... I'm looking for "cheap and simple". I want to stay all Toyota but I'm not looking to make a PROJECT out of the swap.
My personal challenge is learning specific model/years to look for... so many older cars and trucks are now "collectable classics" that prices are out of control, even for old Corollas that you couldn't give away a few years ago.
Toyotadon
  • Turtle Points: 426
  • Male Posts: 267
  • Member since Dec '08
« Reply #7 on: Mar 21, 2021, 10:21:24 PM »
From what I remember in researching the part numbers, the 3RZ and 2RZ blocks are the same. It's just the crankshaft that gives 300 extra milliliters. This would mean the transmission from a 2WD would work with the 3RZ.
Edit: The 3RZ was also used in the PreRunner, which is 2WD on a 4WD chassis and suspension.
sirdeuce
  • Male Posts: 537
« Reply #8 on: Mar 26, 2021, 04:30:22 PM »
Sorry, I get excited when the idea of "what could I swap" comes up.
sirdeuce
  • Male Posts: 537
« Reply #9 on: Apr 11, 2021, 09:38:20 AM »
I have a question that might be relevant to this swap. "Is there a tuning change when switching to 4WD mode?" Pretty sure swapping to 2WD with a 4WD ECU would be fine, but I've heard 4WD doesn't do well with 2WD ECUs. If there is a "4WD tune" in the ECU accessible at the flip of switch......
Lewis Hein
  • Shoutbox Ban
  • Turtle Points: 273
  • Member since Feb '17
« Reply #10 on: Apr 11, 2021, 07:30:52 PM »
With the number of wires going into those ECUs, it'll be more like the flips of 50 switches :gap:
Last post Apr 12, 2006, 07:52:56 AM
by nisserd
Last post Apr 25, 2007, 02:19:56 PM
by CaseyP
Last post Oct 05, 2016, 03:45:13 PM
by Smithk2ski
Last post Jan 19, 2014, 09:42:03 PM
by dustingro
Last post Feb 26, 2014, 06:33:45 AM
by BigMike
