Remove the two nuts and one bolt holding actuator on. With screwdriver pry shiftfork to unlocked position. Locking the unit manually would require jacking it up to allow you to turn the wheels to align the shift hub. You may have to jack up the wheel to unlock it as well. Jacking it up helps unload the shift hub/axles.
