Gnarly4X's 22RE Rebuild
Quote from: Mudder on July 06, 2016, 02:18:21 PM
It must be in the air to rebuild 22re's. I just dropped mine in last Sunday and am waiting for the injectors to come back.  Good to know about that issue with Engnbldr's timing set thoug!
Hi M,
Are you doing complete rebuild.  Engine out of truck?  Who did you send your injectors to?  Are you doing any "extras" while rebuilding it?
#31
....  Good to know about that issue with Engnbldr's timing set thoug!
Well... like Tod said, it may just be my unusual engine block and TC cover issue.  :dunno:
But, I'd like to hear about anyone else that has installed engbldr's T-C kit lately.  :headscratch:
Mudder
My last engine snapped a rod and blew out the block. The only extras I did was put in a 261 cam from Engnbldr with his stock replacement head. The injector deal ended up being a huge mess and either USPS, the company they drop them off to or Witchhunter(which I doubt) lost mine so I ended up ordering some from LCE. If you aren't in a hurry I'd get them cleaned as I heard it makes quite a difference. I'm very interested in seeing your thoughts on the 261C with a header, I still have the stock manifold. The one thing I did for sure do was new engineotor mounts. I used GM transmission mounts which are Polly.
Quote from: Mudder on July 06, 2016, 03:57:52 PM
Wow... rod snapped... isn't that rare for a 22?
261C, what made you chose that one?  I'd really like to hear how you like the 261.  Will you be able to compare it to your last engine?
Sorry to hear someone lost your injectors!  I have already sent mine to WitchHunter and have them sitting on my desk.
The stock header is a good stock header, but a DT header will be VERY noticeable, especially from 2500 to 3500 RPM.  The 22RE is a little sensitive to backpressure - it likes to feel some backpressure.  If you go too big on the exhaust system you will feel a noticeable drop in torque.
What do you guys like to use as gasket sealant on the intake manifold gasket, if any?  I'm leaning towards Ultra Black?
Thanks,
Quote from: toyodaaddict on July 06, 2016, 01:46:29 PM
... I had an issue with the rocker assemble ...
My I ask what kind of issue?
Thanks,
toyodaaddict
Quote from: Gnarly4X on July 06, 2016, 06:31:54 PM
Thanks,
The rocker assemble was rebuilt with new shafts and reconditioned rocker arms and then used in a previous build for a short time (long story). Anyway, I had intended to re use the rocker assembly, but I found that the shafts had some how gotten chewed up. So now I have new shafts and rockers on the way.
Mudder
Yes it is, I have had a rod and a crankshaft break in the two trucks I've had, both were rolled though. I choose the 261C as I was leaning toward the 270 but E-mailed Engnbldr and he suggested I go with the 261 based on their being no intake mods and for exhaust I'll be running 2" to the muffler then 2.25 to the tail pipe.
Quote from: Gnarly4X on July 06, 2016, 06:28:17 PM
Thanks,
As for intake gaskets I've always bought Fel-pro ones. They've got sealant around the edges of the intake manifold to head section and I've never had a leak with them.
Quote from: Mudder on July 06, 2016, 06:52:23 PM
... Engnbldr and he suggested I go with the 261 based on their being no intake mods and for exhaust I'll be running 2" to the muffler then 2.25 to the tail pipe.
Well I hope we have made the choice with the 261.  Yes, the 270 will trade off too much low end torque for high RPM power.  I need more torque.  I  will check out the Fel Pro gaskets.   Thanks.
Mudder
Also, look at picking up some M10x1.25 48mm studs and use those for the starter unless you still have the stock top stud for it. Makes life so so much easier. I will be comparing this one to my stock cam, which I could 75-80 in 4th with it.
 :spin:
Quote from: Mudder on July 06, 2016, 07:27:11 PM
Yes, I think I'd rather get cane'd than installl the starter... it's a bear!!
Gnarls in the garage hot and sweaty  :spin:
Self education is a time consuming thing…
I should have looked at all of the components and parts to check out their condition BEFORE.
Now I have to stop again and take 1.5 hours to get to the Toy dealer and buy parts.  :willynilly:
…. I’m sure it’s because I’m deficient in more than 100 brain cells.  :yikes:
Here are the two water ports that are too rusty and better to replace them now.  :disturbed:
Gnarls  :spin:
OTO Phil
Thanks,
For the intake gasket, I used permatex copper. It's great for higher heat seals like the intake, and works perfectly!
Make sure you're using Toyota red coolant. I buy 1 gallon, dump it in, and fill the rest with distilled water.
#43
Quote from: excabswap on July 07, 2016, 12:00:25 PM
Hey e,
OK, I didn't think about P-copper, I have P-Form-a-gasket #2, P-High Tack, P-Ultra Black.
On the coolant.... like many motorheads I've done lots research on this often debated subject.  I have always used just green EG (ethylene Glycol) mixed with distilled water to 50/50.
Some experts have stated that DexCool has a high pH (alkaline) and can cause corrosion of aluminum surfaces.  The key thing is to make sure you check the pH of whatever coolant you use.  If the pH is too low - too acid, it can be corrosive to metal surfaces.  If the pH is too high - alkaline, it can be corrosive to aluminum alloy.  Over time, the pH typically goes lower, more acidic.
I <should> change my coolant when the pH goes above 10 or lower than 8, or about every 2 years.  You can buy very inexpensive coolant testers.
If you use DexCool or Toyota pink coolant, you should check the pH frequently to make sure it doesn't get too acidic.
I buy WalMart brand coolant...
Mudder
Same boat at Gnarly with the coolant. I have Walmart sitting in my garage with some distilled water. 22re performance says to use a coolant without any phosphates.
OTO Phil
Gotcha.. also, a good note here, the Toyota pink is a premix and is for vehicles 2005 and newer. The red (super long life) is for the older generations
OTO Phil
Quote from: Mudder on July 07, 2016, 01:25:16 PM
Also, make sure there aren't any silicates.
And if you have the original copper  radiator, the organic-acid-technology corrosion inhibitors aren't effective for those metals or the soldering used in those radiators.
Quote from: Gnarly4X on July 07, 2016, 07:18:46 AM
:spin:
I am curious about this as we changed the starter on my 22RE on the road to Moab and it was about a 15 minute project in the Autozone parking lot. What makes yours so difficult?
Quote from: blackdiamond on July 07, 2016, 04:04:08 PM
Hi b,
Well.. I've always used extra long extensions to get to the top stud and nut and bottom bolt.  I do it from the front passenger side. I haven't had much practice at removing or installing them, so I may be doing it wrong.
On my 85 straight axle it seemed like I had more room.  On my current '86 there is a little panel on the fender well that I can remove - never done that - but in my most recent disassembly I could not get to that panel.  This time the stud came out of the bell housing so, I will install it back into the bell housing with some blue Loctite before I drop the engine down onto the motor mounts.  I left the leads connected to the start and laying on the frame.  Since I have never pulled a 22 from a vehicle, I'm wasn't sure the best method for R&R'ing it.
It seems in the past to R&R a starter was always one of those deals that makes me swear at it..... that's probably not a good idea!
I've read posts by guys on other Toy forums that claim to rebuild a 22 in 6 hours.  I'm not saying it's not possible, but I'd sure love to witness that!  I've have spent well over 6 hours just cleaning parts and removing old gaskets! But as I always say, I'm way slower at this than the average.
How do your R&R a starter in 15 minutes?
Mudder
I can do a starter in 15 minutes as I've pulled mine over 30 times in the last year trying to track down an issue with starting. But I'm also a small guy. 5'5" and have skinny arms and small hands so getting in there is easy. I think what makes it easier is not having A/C or being carbed.When I went from carbed to efi the starter was harder to replace but not to bad. But now with A/C I teach my self new ways to cuss trying to get it out.
Update:  5:55 pm  - July 7, 2016
I called the Toyota dealer, Parts Dept couldn’t find the two water by-pass ports, so I called Jerry at 22RE Performance. The big one is available, the little is not.  I ordered the big one.  I did some internet research and could not find something that I could use.  So I cut off the rusty nipple and decided I will figure a way to insert a piece of copper or brass tubing as a nipple.
Since the very short distance that the tube/nipple can be inserted, it may be tricky to get something to seal.  The other option is to fully insert a tube, then drill the end of the inserted part from the little press fit end.
Any suggestions are welcomed!
OTO Phil
Go to a radiator shop and have them silver solder a new one in.. or almost anyone who can silver solder should be able to help you out. Fittings only cost me about $25 to have connected
Quote from: excabswap on July 07, 2016, 05:57:26 PM
Hi e,
Thanks.  Can I silver solder a piece in myself with my propane torch and some silver solder?
OTO Phil
I wouldn't. From what i gathered when i was doing my fuel line fittings, propane doesn't transfer enough heat.
But if propane does work, be careful with the flux.. i don't see why someone couldn't just silver solder in a barbed fitting if they're good at it
Quote from: excabswap on July 07, 2016, 06:02:31 PM
OK, I'll check out my local radiator shop tomorrow morning.
Quote from: Gnarly4X link=topic=100729.msg1124932#msg1124932 date=1467935547.
/quote]
Here is my buddy changing the starter.  I think he did all of it from this angle.  I guess my lift, tires, shock hoops, etc., add up to make access pretty easy.
Quote from: Gnarly4X on July 07, 2016, 05:55:22 PM
I called the Toyota dealer, Parts Dept couldn't find the two water by-pass ports, so I called Jerry at 22RE Performance. The big one is available, the little is not.  I ordered the big one.  I did some internet research and could not find something that I could use.  So I cut off the rusty nipple and decided I will figure a way to insert a piece of copper or brass tubing as a nipple.
Tap the hole for a npt fitting.
Then screw a nipple into it.
Quote from: emsvitil on July 07, 2016, 08:57:34 PM
Hi e,
Thank you for the input.
That is exactly how I first looked at an option.  Drill the port, tap it with NP tap, screw in a new nipple.
I spent some time online and at 3 stores here in CG. trying to locate a threaded nipple that was small enough for the square port. I suppose there's one out there, but - as we used to say in sand dunes - I'm burning daylight as I encounter these delays.
Plan B - drill out the port, insert a brass or copper tube, silver solder it, drill the port from the bottom to make sure the inserted part does not block the water flow.
I'm happy that there parts out there for a 30 year old engine, but we should be aware that some parts are not, and fabricating some replacements are going to be part of keeping these old truck alive.
:)bestgen4runner [08:41 PM]:   I am a Master mechanic, Started working on cars at 12, (really) I specilize in Toyota, master diagnostic toyota mechanic for 13+ years
I clipped that from the chat window...
Geezz b, I just want to say thank you for being here and all that you are willing to share to help us DIYers!  :smooch:  :thumbs:  :beerchug: :clap:
Gnarls. :spin:
7-8 pm - Update on small water by-pass port...
I fabricated a repair with a brass nipple cut off from the piece I bought yesterday.  I drilled the hole with a 5/16" bit.  I filed the end of the brass nipple so I could tap it in with a ball peen hammer.  I don't think it will leak, but I can silver solder it if I have to.  Since it sits on top of the manifold next to the themostat housing I can see if it leak and get to it to fix it.
