Author Topic: Coolant leak on 20r?  (Read 4244 times)
Yotaoverland
  • Male Posts: 208
  • Member since Feb '15
« on: May 27, 2016, 07:40:22 AM »
Does anyone know what may be the cause of this strange coolant leak?
It seems to be coming from under the header? I'm not very sure. Should I be concerned? I'm currently on a road trip, and would rather not have something bad happen.
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
Re: Coolant leak on 20r?
« Reply #1 on: May 27, 2016, 12:57:18 PM »
That's weird.  If it's not getting hot I would guess you are OK but I would do something with it.  JB weld?  I hate to say it but it might be good to retire the block if it has a crack or something.
I'm going to acquire a handful of 20r blocks this year if all goes as planned.  You could just have one. Wonder if we could get one down there reasonably from MT.
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
« Reply #2 on: May 27, 2016, 01:44:02 PM »
Cracked block?
Time to go wheelin!
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,145
  • Member since Sep '08
« Reply #3 on: May 27, 2016, 08:08:00 PM »
Yeah, that pic does make it appear to be a cracked block, hopefully not :crossed:
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #4 on: May 27, 2016, 08:36:50 PM »
do you have milky oil? or oil in your coolant? I wonder if it is possible it is leaking from the head or headgasket, and dripping down to the block?
:)bestgen4runner
  • Turtle Points: 2120
  • Male Posts: 1,796
  • Member since Mar '16
« Reply #5 on: May 28, 2016, 09:17:22 AM »
As a road trip repair I would add a cooling system leak stopper.
Silver seal is the best but bars leak tabs work also. (read and follow the instructions)
This Should help your situation until you are home and can make a larger repair possible.
Best of luck.
I am 1/5th of Perfect Fit
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #6 on: May 28, 2016, 10:31:25 AM »
It will also help clog up your heater core and radiator. Stay away from that garbage. If you have electrolysis build up (like many of these do) in your head and block, pour that junk in there and youe almost guaranteed to be doing a head gasket soon.
That being said. My 80 model had a cracked block since about 83-84. The man I got it from cleaned it with a wire wheel and put some marinetex on it. Still there to this day. If I were in your shoes I'd clean it very well, mix some jb weld (the 4 minute kind) let it set over night and roll with it. I used it on a 5.9 cummins block in a pinch to get it home and as far as I know the man is still running it. Been a few years back since I talked to him.
01 double cab hunting truck
06 tacoma street truck
:)bestgen4runner
  • Male Posts: 1,796
« Reply #7 on: May 28, 2016, 12:52:46 PM »
What the redneck says it true and an excellent caution. I should have included that with my recommendations. This can happen in older vehicles that have components that are near plugged up.
I Have had success using both options (JB weld and seal tabs) for money issue customers and in a pinch situations.
I know that some people dislike them (seal tabs) due to the potentials. If used correctly (not five times, Because more will work better) and the instructions followed properly I have never had an issue Myself. I also would like to mention that Subaru and Cadillac use this same technology as part of the regular maintenance. Seal tabs and cooling system stop leak additive.
http://paceperformance.com/i-6485739-3634621-gm-cooling-system-seal-tabs-for-cadillac-aluminum-engines-other-gm-iron-aluminum-engines.html
http://www.amazon.com/Subaru-SOA635071-Coolant-System-Conditioner/dp/B00IGZP2UE
Subaru does not call it a sealer but trust me, I have used it many times and its a sealer.
I believe there are others that use seal additives strait from the factory.
« Last Edit: May 28, 2016, 07:44:25 PM by :)bestgen4runner »
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #8 on: May 28, 2016, 10:45:55 PM »
This!  Marinetex is the :pokinit:!  Cool thing is, you can install it wet, too.  I've used it to fix leaks on boats while the customers are still on them, as well as to fix barges that cost too much to pull and have down for a couple days to do a proper repair.
Last post Jan 26, 2008, 08:43:06 AM
by nvtoyin21
Last post May 15, 2008, 09:28:26 PM
by Prismo
Last post Jan 25, 2009, 04:41:28 PM
by abeer
Last post Dec 13, 2009, 02:02:50 PM
by 69800
Last post Jun 11, 2011, 05:50:53 AM
by 79coyotefrg
