There is a small coolant hose that goes from the center pipe to the sensor pad makes a 180* bend check that one out. Could be headgasket but the 3.0 was more likely to blow into to the cyl. 3.4 was bad about leaking to the out side. Thers also some small freeze plugs look at them good to.
that center pipe dried out and cracked on mine, was dumping water down the back of the engine, made it look like it was coming out of the head.
Yep and i hope you have small hands
Started by nvtoyin21 Engine
Started by abeer « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by 69800 Engine
Started by sparkys83yota Engine
Started by Yotaoverland Engine
