Author Topic: Has Anyone Have EXP On Sierra Truck Now 209Toyota1 In Modesto For 22RE Rebuilds?  (Read 4269 times)
smc1010720
  • Turtle Points: -1
  • Male Posts: 40
  • Member since Jun '14
Just trying to get a 22RE and 20-22 Weeks For 22REPerfomance Is alot of time to wait. Anyone Know Sierra Truck now 209Toyota1 in Modesto For 22RE Rebuilds?
H8PVMNT
  • Turtle Points: 452
  • Male Posts: 3,554
  • Member since May '07
  • I'LL NEVER MAKE IT...
I always tell everyone...  Rebuild it yourself!  Really really simple job and you will save a ton of cash.  enginebuilder.com for a good deal on the parts.
– Steve McQueen
smc1010720 [OP]
  • Turtle Points: -1
  • Male Posts: 40
There's a machine shop few blocks away. But don't I need macrometers and bore gauge and other precision instruments to build it myselft? I have those (3/8 &1/2) Snap On Torque Wrenches and feeler gauge set.
H8PVMNT
  • Male Posts: 3,554
Well it's nice to plasti-guage the rod and main journals before you do a final assembly but the machine shop can measure everything and put it to spec and tell you what bearings and pistons to order to fit whatever they did. Plasti-guage is like $2.00.  Pick up a tube of engine assembly lube. A cheap engine stand is nice to have. You might need a piston ring compressor to get the pistons back in and maybe a set of those special pliers to install the rings on the pistons.  Other than that if you have the torque wrenches you are good.  I just assembled a bottom end with my 9 and 12 year old and they were both almost disappointed at how simple it was. We are building a 22r in or dining room.
Not everybody likes to do engine work but it's honestly harder to get all the stuff off the engine than it is to reassemble the real meat of the engine.
– Steve McQueen
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
x2!  ive done a few, you dont need all the fancy tools, just patience and the willingness to spend time building it, a FSM helps the most when doing your 1st one.
the machine shop does all the magic, you just assemble it
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
I've built 5 or 6 20/22r's, simple!!! Just take your time and keep everything clean. I'm finishing up another 22re for my dads 93 as we speak, hopefully fire it up tomorrow or saturday! Find a good machine shop and you'll be golden!
smc1010720 [OP]
  • Turtle Points: -1
  • Male Posts: 40
Thanks for input guys. 22REperformance sells the rebuild kits with OEM parts instead of going engnbldr route.
H8PVMNT
  • Male Posts: 3,554
Can't go wrong with Toyota stuff if you have the $$.
– Steve McQueen
smc1010720 [OP]
  • Turtle Points: -1
  • Male Posts: 40
The top of my pistons on the 22RE have a 1.0 those that mean it's a rebuildable core?
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
thats .040'' over, have to mic the bore and see if its within spec to hone. If not, find another block.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
I plan on rebuilding a 22RE.  Just need to get a good spare block.  Bleakhorizon on here lives nearby and he is willing to help me.
smc1010720 [OP]
  • Turtle Points: -1
  • Male Posts: 40
Where you located?
Cheesemaker
  • Male Posts: 4,525
About 9 hours from you in Tillamook, OR.   :gap:
smc1010720 [OP]
  • Turtle Points: -1
  • Male Posts: 40
If I remove the engine will the trans be supported on its own since it's a 4wd I'm concerned about being able to role on the driveway. Or have to put a jack under it?
OVRAROK
  • Turtle Points: 26739
  • Male Posts: 3,522
  • Member since Dec '10
pull the shifters, then use a ratcheting strap with a 2x4 across trans tunnel to support it, and yes it will roll, wheel chocks, e brake
209toyota1
  • Male Posts: 6
  • Member since May '15
  • Toyota engine builder
Hi guys. Nick from 209Toyota1 here. We do ALL of our own machine work in house, we have lots of parts in stock aftermarket and OEM. We usually have 22re's in stock, good ones! We do lots of custom builds, anything you need.  port work, oversize stainless valves, ARP head and rod studs, OEM gaskets, cometic, MLS, cam gears, dual row conversions and lots more. We build great engines and WE STAND BEHIND EM!! We also build 2rz 3rz 3vz 5vz. We at 1230 11th st. In downtown Modesto. Come by anytime. We're working on our website everyday trying to get everything on there, if you need something and don't see it call us we might have it. We're not drop shippers just trying to turn a dollar, if it's on our web site then we have it! If you need machine work done we will gladly do it for you. Call us anytime. Phone number is 209-toyota1  See ya on the trail!!!!
209toyota1.com 209-869-6821
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
:eek:  whats the specs on those "stage 2 cams"  like lift, duration, lobe center?
Last post Jun 10, 2002, 06:01:23 PM
by CableDawg
Last post Sep 07, 2005, 10:35:16 PM
by Skinny_Pedal
Last post May 16, 2007, 10:53:57 AM
by dirtchicken
Last post Mar 27, 2009, 05:03:49 PM
by THK Matt
Last post Oct 10, 2015, 09:50:49 PM
by SlayTank
