I have a 94 4wd 22re that needs an ignition switch, problem is nobody can get the correct one for me. I've tried various parts stores and the dealer. Basically everybody has on listing for switches, it goes from 89-95. The switch I have only has seven pins in the connector, and the shape of the connector is slightly different than the I guess standard eight pin connectors. Anybody encounter this and have a solution? I may get wiring diagrams out and just switch out the connectors, other than those two issues they seem identical.
