Author Topic: Front Driveshaft recipe?  (Read 1948 times)
southern UT runner
  • Member since Dec '06
« on: Dec 26, 2006, 06:09:53 PM »
So I did the Marlin 4" SAS on my '86 Runner. I am running 37" tires. Now the problem is the angle of my front driveshaft, I made a square tube shaft with the stock cv and it is not working. I am running only one case so from flange to flange is 30". I need some ideas on the best most econ. way to put me back on the trail? Thank you all
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
  • out from under my rock, and ready to roll
Re: Front Driveshaft recipe?
« Reply #1 on: Dec 26, 2006, 06:13:05 PM »
Why doesnt it work?   :headscratch:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Dec 26, 2006, 06:14:39 PM »
ditch the cv  and get dual cases as soon as possible
« Reply #3 on: Dec 26, 2006, 06:16:39 PM »
if you used the cv from the 86  thats why it didnt work, the 86-95  cvs  had very little  angle to them
ditch the cv  or get a high angle cv or  better angle one from a 84-85
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
« Reply #4 on: Dec 26, 2006, 06:20:37 PM »
Could you grind the CV to give it more angle? Just wondering cause I'll have my 87 4Runner done this weekend.
87 4Runner redo
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
« Reply #5 on: Dec 26, 2006, 06:24:40 PM »
Try to find the earlier cv, that will help a lot. I thought I read somewhere that you could do a little clearancing on the cv to get a little more out of it, but i'm not positive. (i'd search that one)
You could eliminate the cv with that steep angle, but you'll probably have vibration issues. I've known Jesse at high angle a long time and he has always wanted to take out the cv and just use a single u-joint, but all of my friends that went that route had vibration problems, so I would use the cv elimination as a last resort. But it may be the cheapest fix for you at this point.
Start saving your pennies and buy a dual case. It will solve that problem and make wheelin so much funner.
FIREBALL
« Reply #6 on: Dec 26, 2006, 06:59:39 PM »
I know you've already done your sas, but another option that would help would be to rotate your pinion up a bit and cut and turn your knuckles.
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #7 on: Dec 26, 2006, 07:02:32 PM »
high pinion case wouldnt hurt too
Quote
FIREBALL
« Reply #8 on: Dec 26, 2006, 07:08:25 PM »
Good point, but maybe not the most affordable option unfortunetly. That along with a better pinion angle would definetly help with only having a single case.
89 toy
  • Turtle Points: -1198
  • Male Posts: 383
  • Member since Dec '03
« Reply #9 on: Dec 26, 2006, 09:20:04 PM »
you can clearance the ifs cv joint there is a write up on it. try searching pirate or 4x4wire or yotatech
TRHS1980
  • Turtle Points: 2
  • Male Posts: 234
  • Member since Apr '06
« Reply #10 on: Dec 26, 2006, 10:19:54 PM »
http://www.4x4wire.com/toyota/tech/cvmod/
I think this is it. Good luck!
2007 Tacoma 4x4 6-speed on 35's
"In all affairs it's a healthy thing now and then to hang a question mark on the things you have long taken for granted."
southern UT runner [OP]
« Reply #11 on: Dec 27, 2006, 08:48:38 PM »
I thank all of you for the response. this was build up number 2. just doing things in the wrong order this time around. I have the extra case so I might as well do the dual's now.
I DO HAVE ONE  MORE QUESTION, I WAS TOLD THE NEWER THAN 1988 CV WILL WORK AS WELL. i HAVE A LATER V6 FRONT SHAFT AND IT IS THE SAME LAME CV. Thanks again for all the help
Last post Sep 12, 2004, 07:20:08 PM
by toyotaboy
Last post Jan 15, 2005, 10:45:13 PM
by lilbuddy
Last post Feb 13, 2005, 04:57:48 PM
by tdawg
Last post Aug 10, 2011, 09:17:30 PM
by *** YELLER ***
Last post Nov 25, 2012, 06:20:31 PM
by brainlessfool
