I have a wired set up, it is a 84 ext. cab on a 85 four runner frame and running gear, with a 87 efi motor swap. Now my problem is, when i drive it starts to bog down and sputter and pop and hesitate when you give it full throttle but if you baby it, it doesn't do quite as bad. I thought it was the alternator (the battery isn't holding a charge) put it in and it didn't work battery still loses charge so i had it tested 4 differant times all say its good, changed coil, new battery, computer, people have told me that it is fuel but it isn't consitant. could it be distributer, timing, or fuel?
