more problems
Started by BLACKDOG, December 09, 2004, 07:08:39 PM
BLACKDOG
well, the curse is back.
Just when i was thinking everythuing was going to be running again, something else breaks :smack:   This time i think it is the transmission, i really hope it isnt.  In first it is fine, but when i am in second or higher, and i give my truck gas, there is a vibration of some sort.  it is only when i push on the gas, and it speeds up with higher rpms.  however, there is no preformance suffering, so i am not sure what it is
:help:  :help:  :help:
              -Ronald Reagan
yotaboy79
probably tranny but check to see if your driveline bolts are loose
Skinny_Pedal
ujoint. i have driven on broken ujoints for a couple hundred miles thinking my tranny was funked up.
Im an OG
BLACKDOG
why wouldnt it do that under coasting condition? why is it only under power?  I really hope you are right  :beerchug:
              -Ronald Reagan
Skinny_Pedal
when mine was busted and coasted the truck rattled.  i would give it gas and it would shake a little and it would be hard to shift. 1st wasnt bad just all the other gears. im betting u just have a busted u joint
Im an OG
BLACKDOG
that sounds exactly like what exactly is happening.  THanks 86 :beerchug:
Have a beer or three on me and a turtle point
:beer:  :beer:  :beer:
              -Ronald Reagan
SWAMPER
BLACKDOG
its dark, and i already burnt out my spotlight earlier from working on my diff in the dark. :slap:   but i will in the morning, and mabye get the part tommorow afternoon, seeing as it is just a broken u joint (thinking positively)
              -Ronald Reagan
SWAMPER
If it is the U-joint which one will you get...try and get a HD type I have Bruteforce HD U-Joints and I am very happy with them...after I had them for around a year a popular 4x4 magazine did a write up on the 10  best aftermarked u joints and BF Hd joints were on there...not bad for around 12 bucks a pop at Autozone
FATB0Y
I had an 82 Datsumbit*h w/ :tantrum:  a spool in the rear  it would bust a u joint every 310-325 miles you could set your trip odometer and it was just like it knew how many miles was on it and it would start vibrating had to keep a spare in the glove box. But I did get where I could change one in under 10 min. 8) BTW BD do ya have a pic of your new spotter w/o your mug covering her up?  :angel:
DontStall Rockcrwl
sounds like the exact problem i have. i was told it was my driveline angle because its only happening after i installed my dual t-cases. but maybe it is the u-joints?? its only when i give it hard gas and coasting, but when i give it little gas the noise doesnt occur..
You have all gotta be jealous how close i live to the 'Con
BLACKDOG
sounds pretty much like that is the problem.  I did crawl under the truck before i wentto work todaY, and i didnnt find a whole lot, although the ujoint at the front of the rear drive line doesnt look quite right to me.  Had a bunch of crap all over it too, so i didnt get a good look at it
BTw :03hdfatboy, i do indeed have more pictures of my spotter, check out MY avitar, not hers.  thought this was a truck forum though?  what, do we need to start a girlfriend/significant other thread? :smack: I'll leave that one up to you  :beerchug:
              -Ronald Reagan
brainlessfool
check the out put flange on the transfrecase too. matbe the nuts loose.  :psss:
BLACKDOG
thanks BF, I'll take back all those horribel, terrible, dirty, no good, rotten, mean things I said about you  :beerchug:
              -Ronald Reagan
brainlessfool
Quote from: blackdog on December 10, 2004, 12:00:42 PM
  F with my rep will ya?  :bat:
:smooch:  :rofl:
SWAMPER
yotaboy79
if none of that stuff is bad drain the oil in the tranny and t-case and check for metal shavings or in my experiance gearteath and ball bearings :_oops:  :beerchug:
FATB0Y
Quote from: blackdog on December 10, 2004, 11:00:53 AM
:hammerhead: But its so tiny and I'm old and can't see :eyecrazy:
BLACKDOG
well, if you are so old, i dunno if i want you oggling my 19 year old girlfriend :hammerhead:  :beerchug:
ya old fart  :haha:
              -Ronald Reagan
FATB0Y
 :rivers: I'm not THAT old. :rivers: But my oldest kid will be 19 in June
kyle_22r
i had the same symptoms but it ended up being my pinion gear blowing up.  had a good vibration and a lot of banging coming out of the rear diff :_oops:
BLACKDOG
yeah, that is kinda what ruger and i have narrowed it down to.  we had the rear up on a jack, and the front braced against a curb, and it was vibrating like crazy :nerv:   it was pretty cool, going about 25-30 with moving.  were taking it apart tommorow, so we'll see what is going on :crossed:
              -Ronald Reagan
FATB0Y
Skinny_Pedal
did u just look at it or did u actually shacke the dline to c if the ujoint is funked. usually the bearing crack
Im an OG
BLACKDOG
we shook it, it really seems to be the rear end  :down:  but we will find out tommorow for sure
              -Ronald Reagan
FATB0Y
BLACKDOG
Diagnosis?  Pinion Gear started spitting teeth.  Hopefully the detroit is ok, gotta get the work done this week.
              -Ronald Reagan
FATB0Y
BLACKDOG
yeah, me too.  Oh well, it happens, life goes on.  I now have a complete front end, and a rear third laying on the deck of my apartment complex.  I have a trashbag wrapped around the rear end, and I am driving my parents car :shudder:  a burgandy chrysler cirrus.  I DONT KNOW WHAT TO DO WHILE I AM DRIVNG!!!  I almost threw myself through the windsheild when i tried to hit the clutch, (auto) and nailed the left side of the brake petal.
hopefully I can get my third rebuilt tommorow or tuesday, so i can drive my truck again.  :rockingout:
              -Ronald Reagan
SWAMPER
I hate driving cars...specialy at night when theres a truck behind you the headlights hit you on the rear view mirror and blind the living smokes out of you :tantrum:
