4x4 problems
Started by BLACKDOG, October 21, 2004, 08:25:18 PM
BLACKDOG
 :help:decided to go 4 wheeling earlier.  4x4 decided to go out on me  :rivers:
i heard a really loud pop from the front end, and then sounded like a scraping/grinding sound when I was in 4x4.  Had a friend check it out, and even when I am in 4 wheel drive, I'm not. :rivers:  I dont want to take it apart until I know what I am getting into.  I have a feeling I broke the ring gear, but I am not sure.  Truck runs fine in 2 wheel, no problems at all but now as soon as I lock up the hubs, the truck wont move.  Almost like something is wedged in the gears.
Any Ideas??
:help:
              -Ronald Reagan
$10 says you had your tires turned when it happened.
Is this IFS or live axle?
It's got to be either the hubs or the ring&pinion.  Do you have stock gears?
birfs go long before hubs and diffs
BLACKDOG
IFS with 5.29 gears.  I was actually going striaght at the time
              -Ronald Reagan
Mike D
IFS there ya go  :-\\ could have been the inner axle shaft.
BLACKDOG
how bad is that??  and how easy is it to fix (i live in an apartment complex w/o a complete set of tools  :(  )
              -Ronald Reagan
Mike D
thats a lot of work and you need a full set of tools  :hammerhead:  :_order:
BLACKDOG
              -Ronald Reagan
Mike D
well then hopefully it isn't that  :crossed:
BLACKDOG
Anyway I can figure out what it is for sure without taking it completey apart??  I cant be without my DD for more than a weekend
              -Ronald Reagan
Mike D
yikes but yeah an axle shft can be done in a day if you have the right tools and parts
Prismo
Put the front on jack stands, spin front driveshaft. Listen for unusual sounds while spinning the front driveshaft. Lock in 1 hub, spin driveshaft, now the other one. It helps to have the truck in nuetral when doing this test. Check the play at the flanges, diff & transfer case.
Quote from: blackdog on October 21, 2004, 08:34:32 PM
on pavement ? on rocks??
maybe a pinion gear snaped off,   :sad2:
UNBREAKABLE
I've got an idea. Say  :fakeflip: to that damn IFS and put in a solid axle.
That's how I roll
BLACKDOG
I would really like to do a SAS.  However for someone with NO money, it is out of the question right now.  I have a total of like 150 right now.  And I have bad news.  I drained my front diff earlier, and I got small chunks of metal falling out of the hole :nerv:  I'm assuming gears??  also, when I stuck my finger in the hole, it felt almost like i was sticking my finger into the center hole of a bearing.  Is there one in there that could have fallen over the drain hole??
I am completely lost right now.  can ya'll help me out??
              -Ronald Reagan
rockhound
Don't IFS have a steel diff cover bolted to the diff housing?
How you 'sposed to know what your limitations are, till you exceed them.
www.RunandPlayMotorsports.com
Mike D
jerk that cover off and see what ya got,
robinhood4x4
Go to pirate and find somebody who's selling their IFS third member after they did an SAS.
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
