Author Topic: Filling the Tranny  (Read 1733 times)
Weldo
  • Turtle Points: 101
  • Male Posts: 454
  • Member since Jan '05
  • Use what you can, make what you can't.
Filling the Tranny
« on: Jul 08, 2006, 07:55:28 AM »
Can I fill my transmission and T-case from the shifter holes on top, or do I have to use the fill plugs underneath?  Its a w56c, forward shift T-case.
b_ripper8
  • Turtle Points: 371
  • Male Posts: 275
  • Member since May '04
  • 3RZ-FE power is that much closer.
Re: Filling the Tranny
« Reply #1 on: Jul 08, 2006, 08:44:20 AM »
You'll probably over or underfill if you do it that way. It's best to take the plugs out of the side.
In Progress: 3RZ-FE Swap Underway.
Currently: 87' 4Runner - SAS - 5.29's - welded rear - Dual 2.28 cases - Optima bluetop - round headlight conversion - FZJ80 grill - rattlecan paint job - trimmed fenders - Ranger hybrid springs front - Tacoma hybrid springs rear - schedule 160 drivelines 8" slip front - Marlin's crossmember - disk brake conversion
RustyToy
  • Turtle Points: 481
  • Member since Dec '03
« Reply #2 on: Jul 08, 2006, 06:30:47 PM »
it shure is easier to pour into the top, just take out the side plug so you know when to stop...
b_ripper8
  • Male Posts: 275
« Reply #3 on: Jul 09, 2006, 07:04:10 PM »
It's just as easy with a hand pump.
Weldo [OP]
  • Male Posts: 454
« Reply #4 on: Jul 09, 2006, 07:12:03 PM »
I took care of it.  The T-case I got from underneath, but the tranny I filled from the top.  I ran a small rubber hose through the hole in the floor to the fill plug in the trans and poured the oil in through the hose.  I wasn't sure if pouring oil into the T-case shifter would get oil to the T-case itself, because it's a forward shift.
toynizzy
  • Turtle Points: -43
  • Male Posts: 125
  • Member since Aug '05
  • wheel it till it breaks then fix and go again!!
« Reply #5 on: Jul 09, 2006, 10:20:46 PM »
x2 on using the side fill plug,just use a bit of hose and make a squirt bottle outta it,easy and cheap.can be done from the top but i would think it would take longer to take the cover of the top than use the side.
85 xtra cab pretty stock for now but lots of stuff to come!!
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
« Reply #6 on: Jul 09, 2006, 10:32:39 PM »
5 gallon bucket with a hand pump plus you get a better deal buying it in a 5 gallon bucket
Last post Jul 25, 2002, 04:31:45 PM
by Brandon
Last post Mar 22, 2007, 01:36:10 PM
by Fearofrunner
Last post Mar 04, 2008, 12:45:25 PM
by Rocksurfer
Last post Apr 27, 2010, 02:50:16 PM
by Dr.Maxwe001
Last post Nov 12, 2013, 09:57:00 AM
by nship
