Author Topic: Upper A-Arm resting on bump stop ?  (Read 2262 times)
Hylander
  • Male Posts: 15
  • Member since Jun '05
    • California Predators Club
« on: Jul 02, 2005, 11:23:40 AM »
Howd'y All:
First 1990 IFS. 4" Lift
My upper A-Arm's are touching the bump stop's, this can't be good.
I basically have no downtravel,  Right ?
I'm guessing my Torsion bars are cranked to much, so I need to back them off, But how much ?
How much clearance should be between the A-Arm and the Bump Stop.
Failure is not an option
silver_truck
  • Turtle Points: 44
Re: Upper A-Arm resting on bump stop ?
« Reply #1 on: Jul 02, 2005, 12:05:22 PM »
stock you should have between 14-15" at the rim lip to fender lip so I'm guessing w/ 4" of lift it would be 18-19" I dunno about the bumpstop measurements though, seems like it would be kinda a pain to measure it :dunno: . Try your wheel to fender and post what that is.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Jul 02, 2005, 05:21:51 PM »
can you pull a tire off and give us some pics
Hylander [OP]
  • Male Posts: 15
« Reply #3 on: Jul 02, 2005, 10:57:14 PM »
Quote
Can Do
Will post some pics in the morning
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Jul 03, 2005, 12:29:23 AM »
You are correct the bars are cranked all the way up, just start loosening the bars until you can put a couple fingers between the a-arm and the bumpstops. You don't have much travel in the first place. Then go to an offroad store and get the flat bumpstops and that should give you even more down travel. You will be loosing some lift by doing this but the improved ride is worth it. If you plan on keeping IFS get the Rancho upper a-arm, it does not give you very much in the way of lift but it does give you even more travel.
Hylander [OP]
  • Male Posts: 15
« Reply #5 on: Jul 03, 2005, 05:11:59 PM »
Here it is:
  • Momentum Man
  • Lego Enforcement
« Reply #6 on: Jul 06, 2005, 08:19:52 AM »
Yup, they're cranked all the way up. Do what I said earlier and they will give you more travel, and if you get the flat bump stops  it will give you a little more down travel. Get the Rancho a-arm and you'll get even more. Remember it is a trade-off, uncrank those and you'll lower the truck but you'll get a better ride and more equal travel of your suspension..... or you could just hack the whole thing off and SAS the mother.
Last post Oct 20, 2004, 08:20:01 AM
by FXR UPR
Last post Sep 06, 2005, 01:53:44 PM
by blackdiamond
Last post Aug 05, 2009, 07:09:35 AM
by *ROKTOY*
Last post Aug 02, 2010, 07:28:39 AM
by crazykooter
Last post Jan 30, 2020, 05:26:43 AM
by OVRAROK
