Author Topic: electrical worries, please help..  (Read 1153 times)
DRTYLUVN
  • Turtle Points: -19
  • Member since Oct '11
« on: Jun 06, 2012, 08:15:10 AM »
hello guys i need some help to track down my electrical problem
i just came back from a 3 day weekend and started driving my truck again
well i drove it around town just fine and made a quick stop at my moms house to drop off some stuff,
came out and couldnt start my truck
(it seemed to have a little trouble cranking then usual, but i paid no mind cause it sat for 3 days)
it seemed like the last time i had a blown fusable link that went to the battery (+)
power turns on and stays on (when the link was blown before the power wouldnt stay on), starter clicks, but wont turn over
tried jumpin with a battery booster and a car just incase it was my battery, still wont start
checked my fusable link again and everything looked fine
checked battery connections to the starter and alternator still nothing
no blown fuses that i could see
so we towed it back to my house which is like 3 blocks away with my bros camry
got it on the driveway and disconnected the battery
let it sit for a few hours then re-connected the battery started up like a champ
totally confused
the only thing that i noticed is that when i signal left it blinks/clicks at the regular pace
then if i signal right it blinks/clicks really fast
the only other electrical things i have hooked up is my arb compressor for my lockers and my stereo, all 3 switches for my compressor comes to the stereo din/opening
please help, i dont know where to start the chase
it also seems that the previous owner jumped the right head-light straight to a power source but i cant see where it goes after the firewall, he must have had issues with that headlight before
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
Re: electrical worries, please help..
« Reply #1 on: Jun 06, 2012, 12:40:26 PM »
..... do you have a blinker that is burned out on that side?
what year is your rig?
Those are some huge welds!
Tillamook, OR
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #2 on: Jun 06, 2012, 12:46:09 PM »
you said "starter clicks, but wont start."    Have you pulled the starter out and tested it?  I would start there.
Volt meter to your battery reading?   you said power comes on and stays on.
Blinker is most likely a separate issue.  they fast blink when one of the bulbs is out.  or a short, or a fuse.
good luck.
I like to Drive!
DRTYLUVN [OP]
« Reply #3 on: Jun 06, 2012, 01:29:07 PM »
bleakhorizon- sorry its an 85 toy pickup, just heard about the light/fuse mite be out that causes the fast blinking
wermz- i was just informed about that starter being the problem too after i described to the techs here at work, sounds like a     starter going bad, doesnt do it all the time so far its been 2 times, both times near my home, i'll check to make sure before i head out to the hills to test out my/this newly built rig
thanks for your help
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #4 on: Jun 06, 2012, 01:50:00 PM »
That is what it sounds like to me.  Either it is going bad, or the wires and/or connections to the starter need work.  I would also check them and make sure they are clean solid connections.
:thumbs:
I like to Drive!
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
DRTYLUVN [OP]
« Reply #6 on: Jun 06, 2012, 02:51:45 PM »
thanks guys for your help
now i have somewhere to start looking
Rockdiver
  • Turtle Points: -118
  • Male Posts: 671
  • Member since Apr '04
« Reply #7 on: Jun 06, 2012, 06:40:08 PM »
My 85 after siting for a month or so doesnt start like that . I just tap on the starter and it starts fine after that.
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
« Reply #8 on: Jun 06, 2012, 08:18:16 PM »
X2... Sometimes a light tap works to get the funk outof the brushes in the starter
Tillamook, OR
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #9 on: Jun 06, 2012, 10:19:44 PM »
This is a very common problem with older Toyotas.  As a matter of fact, my BIL carries a ball peen hammer, and I a rather large marlin spike in our rigs, just for the whacking of starters.  :_order:  Neither of us have gotten around to install a relay to upgrade the starting issue.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #10 on: Jun 07, 2012, 03:28:03 AM »
Yep, every now and then I have to give my starter a tap or two to make it come back. There could be a couple reasons this happens and they are related. You probably have a weak starter armature and a weak ignition switch. A common issue with older Toyota's and Samurai's, the fix is a simple one by using a relay between the ignition and the starter. Wire the switch side on the low voltage side of the relay and the starter side through the high voltage side of the relay. Wire the other side normally to the battery. This will give you less strain on the switch side since all it will now do is trigger the high side. The added power to the armature will keep it from sticking. I've been thinking about doing my 85 since it has recently started sticking.
DRTYLUVN [OP]
« Reply #11 on: Jun 07, 2012, 07:51:15 AM »
cheesemaker- sounds like a good idea for me to do the same
rocksurfer- thanks for the tip, now just gotta get around to doing it
thanks again guys for your input
Last post Feb 19, 2006, 03:05:02 PM
by skunkyoda
Last post Nov 23, 2006, 03:35:14 PM
by Johnny5
Last post Apr 07, 2007, 07:46:29 AM
by skipnrocks
Last post Mar 14, 2008, 12:01:40 PM
by pjr
Last post Aug 29, 2008, 05:30:12 AM
by jimbo74
