Author Topic: Left headlight and wipers don't work  (Read 1816 times)
Jagdverband44
  • Turtle Points: -1
  • Male Posts: 155
  • Member since Mar '07
« on: Dec 03, 2010, 10:23:27 AM »
Got another problem with my 85' 4runner that I cant figure out. No fuses blown or fusible links (little boxes right?) heard a welder arc sound about three times before the problem. Just a nightmare, this 85', rust holes in firewall let water drip into the cab but sound was coming from engine bay. Anyone have any ideas? How do I check for a short circuit? Thx.
I've got the most liftedest truck in town, that little jap truck done stand no chance gainst my Chevy. My Chevy gots a V8 more lift an bigger tires,and an exhaust system, whats yer tuna can got, a V4, and them tires look like they is offa Saturn Corulla. The dealer instulled my lift, so ya no its done right, you just try to foller me throo them rocks an see what a reel truck can do.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Left headlight and wipers don't work
« Reply #1 on: Dec 03, 2010, 02:49:56 PM »
the ground inside the steering column is bad  :thumbs: get some bulb grease and pull it apart
Jagdverband44 [OP]
  • Turtle Points: -1
  • Male Posts: 155
« Reply #2 on: Dec 03, 2010, 04:56:05 PM »
Your my hero frog! Knew it was something simple.  :biggthumpup:
85_yote_94
  • Turtle Points: -2
  • Member since Apr '11
« Reply #3 on: Apr 24, 2011, 09:59:18 PM »
hey, my turn signals not workin at all. not even the arrows on the dash. and my wipers just recently quick working. any tips?
Jagdverband44 [OP]
  • Turtle Points: -1
  • Male Posts: 155
« Reply #4 on: Apr 28, 2011, 12:56:03 PM »
Check the fusible links in the little box on the Right front fender. Fuse box as well. Simple first, then trace circuit if fuses aren't blown with a multi meter.
Greencorey
  • Turtle Points: 4
  • Male Posts: 38
  • Member since Aug '05
« Reply #5 on: Apr 30, 2011, 09:27:24 AM »
Make sure the wire is not broken some where. With the line not energised or battery disconnected do a continuity test from switch to load and then test from switch to source.
"If you don't live for something you'll die for nothing"
-Hatebreed
Last post Jul 05, 2004, 07:51:53 AM
by SWAMPER
Last post Sep 02, 2004, 08:37:54 AM
by Brandon
Last post Feb 14, 2008, 02:05:46 PM
by H8Mud
Last post Feb 05, 2010, 11:30:49 PM
by 44magnum
Last post Mar 15, 2020, 10:18:09 AM
by RN48
