Author Topic: HELP!!! 22re spark problem!! (1995)sr5  (Read 899 times)
high lakes wheeler
  • Male Posts: 72
  • Member since Nov '05
  • Crawling The Crick!
« on: Apr 29, 2009, 03:04:15 PM »
alright  :turtle: guys time to pick your brains a little bit! OK so I've have done a motor swap with a 1995 22re into a first gen (1981). i had a donor vehicle that i got the motor, (full) wiring harness, trany, and rear axle from. all of the wires are hooked up, i had a problem with the fuel pump not working so i ran it to a switch, now its not attached to the ECU, is this a problem??? i got the fuel to run to the intake but now i have no spark. i tested from the coil wire and i have nothing. i hope its not the igniter is there anyway of testing it? well i hope you guys could shed some light on this problem for me! thank you for your input!!  :usa: :beerchug:
Not jump'n the crick! Crawl'n it!
jeff94runner
  • Male Posts: 138
  • Member since Jun '08
Re: HELP!!! 22re spark problem!! (1995)sr5
« Reply #1 on: Apr 30, 2009, 02:36:29 PM »
You want to check out www.ncttora.com. Find the 95 runner manual and look under the ignition  section of the 22re.  I hope this helps.
"Keeping the heavy light the heavy can be handled"
Last post Sep 28, 2002, 06:56:19 AM
by crash
Last post Aug 24, 2005, 09:45:10 AM
by germ
Last post May 06, 2006, 12:20:45 PM
by kneedownnate
Last post Aug 17, 2013, 01:18:02 PM
by Huff
Last post Jun 25, 2018, 11:17:34 AM
by EASYRYDERDANGER
