Author Topic: EFI or Propane?  (Read 13427 times)
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: EFI or Propane?
« Reply #30 on: Jul 11, 2005, 09:54:51 PM »
copy and pasted from Got Propanes FAQ
"Will propane hurt my engine?
NO! In fact, propane is on the light end of the hydrocarbon scale, meaning there is almost no carbon in it. Carbon is what turns your motor oil black. As a result of using a propane system, your oil will stay clean in a new engine and will get cleaner each time on an existing engine. Because propane goes into the engine as a vapor, there is no "raw" fuel entering the cylinders, which washes past the piston rings and into the oil. This is a major reason propane engines last about three times as long as a gasoline engine.
Propane will not burn the valves. On older engines withour hardened valve seats,this used to be a problem.Even this wasn't a problem until tons of miles were accumulated.On engines designed to run unleaded-no worries."
Last post Oct 16, 2003, 12:21:12 PM
by mills4rnr
Last post Sep 09, 2004, 12:49:48 PM
by tufluv82toy
Propane?
Last post Mar 22, 2005, 12:24:21 PM
by burnyota
Last post Jun 27, 2005, 10:51:11 PM
by trevinotrek
Last post Apr 07, 2006, 08:10:31 AM
by AzBearFan
