Author Topic: 89 22re running problem-  (Read 2114 times)
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
Re: 89 22re running problem-
« on: May 01, 2012, 06:59:13 AM »
Is the intake tube on? If not the MAF sensor will not work and the fuel pump will cut off like you said it does. But, you said you jumpered the pump to run continuous..........hmmm.  Any codes?
It may not be the problem but, you should change your fuel filter like Snowtoy mentioned. If the pump was full of rust, the filter probably is too.
Last post Oct 27, 2006, 07:14:17 PM
by 86turboyota
Last post Nov 27, 2006, 06:15:56 PM
by bolus131
Last post Sep 22, 2007, 01:56:41 PM
by underated
Last post Mar 06, 2011, 06:25:48 PM
by Jaysen
Last post Nov 26, 2014, 03:37:56 PM
by 1985CRAWLER
