Sweet,looks good.I'd hate to have to replace the starter though.Looks like it would be a real pita.
Cebby,With the IFS and front sump, did you ever decide what you'll do for oil pan to diff clearance?I've been told that a front sump will work with the IFS if one does a 2" body lift. If no body lift is used then a Castlemaine Rod Shop (CRS) in OZ makes a pan for the conversion. I think they make motor mounts to suit as well.JR
Hey there CebbyI have been driving mine for 3 days now. I am running a 1.5" body lift. I had to remove the steering stabilizer and slightly dent the oil pan to allow clearance of the center link. I have been driving around with only the stock condensor fan pushing air thru the stock radiator. The temp gauge does not move above t-stat temp with this setup. I do not have a/c hooked up yet. outside temp here was in the mid 90 degree range. I set up the cooling system with temp hoses until I decide for sure which radiator to run. At this point I am leaning towards keeping the stock 3.0 radiator. I would be able to fit a Spal 16" x 2.05" fan as a puller. These are only rated at 1300 cfm so I am not sure.More to comeFrank
Started by cebby Engine
Started by jeremiah Parts Wanted
Started by christyle Toyota Pickup/4Runner Tech 1979-95
Started by wrenchtech Toyota Pickup/4Runner Tech 1979-95
Started by Aznwolf118 Toyota Pickup/4Runner Tech 1979-95
