Wow Cebby, I have never taken one of those apart. I know that they don't come as seperate parts, so you might want to try a Ls400 pulley without the hydraulic fan setup. It should bolt right in and give you less headaches. They are a ton of money new though, so I would check the wrecking yard if I was you. Kinda sucks when you try to save a few buck and then end up costing yourself more, doesn't it?
Same rules about the amount of FIPG as with the waterpump? I noticed what appeared to be alot of the silver stuff squished through on the inside area of the pan.
Here's a link to there site:http://www.jbaheaders.com/index.asp
Started by cebby Engine
Started by jeremiah Parts Wanted
Started by christyle Toyota Pickup/4Runner Tech 1979-95
Started by wrenchtech Toyota Pickup/4Runner Tech 1979-95
Started by Aznwolf118 Toyota Pickup/4Runner Tech 1979-95
