A new thread will be coming soon. I have decided to put this thread to DEATH.I've been really sneaky and have a lot of updates to share
First, it will kool the intake charge to help prevent compression combustion (pinging).
I no longer have an intake air heater so I no longer have a need to cool my intake charge.
Second, because the water is incompressible, it effectively reduces the size of the combustion chamber increasing the compression ratio.
Don't forget, as the compression in the chamber increases, so does the boiling temperature of the water. It is very likely that at the top of the compression stroke there is enough pressure in the chamber to force the vaporized water droplets to condense back to a liquid form.
hey mike i was wondering if you had more pics of how you mounted your rear shocksi noticed that in post # 232 it is higher up on the housing and then in post # 385 they were different and mounted towards the bottom of the housing... do you have any pics of those off hand?
Well, again, I've been changing a lot on my rig. I will be creating a new project thread hopefully the first week of June.I am now on my 3rd version of these lower mounts. They are simple to make. I just build a L bracket with about a 75-degree bend to them, put the shock bolt through them and the shock and then put the nut on and cut the bolt down so it no longer sticks out past the nut. Then I use a small ratchet strap around the entire shock and slowly adjust the length of the ratchet strap and make measurements where I think they should be mounted (all while the shocks are still mounted at the top). Then I put in a couple tacks on the bottom of the L bracket and a couple tacks on the nut-to-the-housing. Then I pull out the bolt, get the shock outta there, and then put the bolt back in to hold the nut in place. Then I just burn everything on, let it cool, throw some paint on it, remount the shock, and wa-la.Do you guys notice anything else unusual with my diff housing?
Hi-Pinion w/ E-Locker? on the front?
thanks for that tid bit of info.... i never thought about using a ratchet strap to compress the shocks and adjust
tips and tricks are simple and you can show off to your friends if they dont know about it....
and im not catching what your trying to point out on the rear diff housing Mike
I'll take a shot at it. No wheelspacers and the diff housing is not in view, but the axle housing looks like the center section has been clocked. That is to say the axle tubes are in the stock location and the center section of the axle housing has been cut, turned and re-welded.
I'll take a bet that you are right!
Started by BigMike « 1 2 ... 38 39 » Project Research and Build-Ups
Started by 6.72:1 Rig Gallery
Started by ZukIzzy Chit Chat Camp
Started by 82rustbeast « 1 2 » Project Research and Build-Ups
