My transfer case is leaking out of the shifter on the front transfer case. I just replaced the rubber boot on the shifter and it appears to be leaking from under the boot. I also ordered an oil slinger and didn't notice if there was one or not when I pulled the shifter to refill the t-case.
Is this likely to be a slightly overfill that will equalize or something else? If I pull the shifter again does the oil slinger just go in like a gasket between the shifter base and the seat on the case? Do I need to use any sealer?
I don't think there is a risk of failure from this leak, but would prefer to get it resolved.
