I Just put a fj 80 axle under my f toy . It has a duel ended steering ram 6 inch stroke.It does not cut as sharp as the mini truck axle did.Can I put an 8 inch stroke ram on an fj80 axle?Thanks for any help or information
Yes you can run an 8" ram, I forget what the # is, but it is not quite 8. Dis-connect the ram and measure the steering it yourself, you may need to replace the ram with a tie-rod temporarily to measure the swing.
Started by Gearhead Wiki Toyota Pickup/4Runner Tech 1979-95
Started by rrick Toyota Pickup/4Runner Tech 1979-95
Started by yota_krawler Project Research and Build-Ups
Started by Gewehr43 General 4WD Discussion
Started by h8z2luze Newbie Questions
