94 4runner SR5 family wagon
Started by 4x4yota, October 25, 2014, 08:06:34 PM
4x4yota
thought id start a build for my 94 SR5 4runner
had her for a few years and last mar/apr she finally blew a headgasket at 220K miles had her for sale with no serious interest so she sat till recently when I moved and now have a garage to work on her.
stock:
3.0 V6 auto
4wd IFS
4.88s
build plans:
3.4 swap
auto w/4.7 case
low SAS
lockers
armor
when I got here and threw on some 33x10.5s
been tearing into the last couple weeks couple hours a day after work
Current:
Sold:
4x4yota
3.4 ready to go
3.4 in
start of SAS
Current:
Sold:
86bobbedtoy
4x4yota
after countless hours and tons of research I finally have my wiring mapped out and ready to proceed
but now I cant find my wire strippers :mad:
Current:
Sold:
4x4yota
started soldering the harness adapter tonight
about 90% complete need to lengthen a few wires and attach them to engine components but otherwise its done
Current:
Sold:
86bobbedtoy
John Doe
4x4yota
#7
got some more work done on the SAS
also cleaned up the oil pan/sump
found my thrust bearings in the pan aswell
Current:
Sold:
Bam
You're making your own wire harnes?
Is there nobody that makes one?
Ugh.... I have a lot of research to do.
"Buy it, use it, break it, fix it, trash it, change it, mail, upgrade it..." - Daft Punk
4x4yota
Quote from: Bam on November 29, 2014, 05:58:33 PM
ORS makes a conversation harness I'm just doing my build on the cheap but if I had the money I'd just buy the harness...
Current:
Sold:
4x4yota
No pics but I did get the tach mod done thanks to a friend/co worker and got my interior back together other than the ecu and glove box area.
still working on the exhaust so the engine isn't fully seated...
waiting on an axle rebuild kit from marlin crawler so I can reassemble and mount the front axle.
tossed a spare 4cyl 4.10 diff in the rear so I can make it mobile again and might run it till I can get a locked V6 3rd to handle the 3.4
Current:
Sold:
4x4yota
got some more done...
got my marlin front axle rebuild kit last week
swapped over the 3.0 oil pan w/ new gaskets
got my frame tube shackle mounts even and square
hung the front springs
shackle angle looks good (4" shackle plates on stock 84 front sprinsgs)
front axle set in place
and finally got the rest of my dash back together and the wiring tucked away
little guy helping
Current:
Sold:
4x4yota
Not much progress on the build just been collecting parts
got a top shift t-case
long field hub fears
also got
SS brake lines
marlin axle rebuild kit
Current:
Sold:
lostbuckaroo
81 shortbed
twistedtoy92
4x4yota
Current:
Sold:
