92 4Runner build 3.4 swap
Started by voodoo556, September 28, 2014, 04:35:14 PM
voodoo556
This is the start of my build.
1992 4 Runner, 3.0 with a 5 speed.
Motor was pretty tired with low compression in #1 and 3 cylinders, so tore into it and decided to pulled the 3.0.
Found a 5VZFE 3.4 out of a 2001 4runner with fairly low miles for a decent price.
They say hindsight is 20/20. Wish I would of just bought a complete donor vehicle!
I want to keep my 5 speed manual transmission.
My plan is to go with an Offroadsulutions wiring harness for the swap.
http://www.offroadsolutions.com/products/ors-stand-alone-3-4l-conversion-harness/
So...current swap status is I'm looking for an ECU out of the following:
96-01 Tacoma 4x4 M/T 3.4
96-01 T100 4x4 M/T 3.4
In speaking with Mike at ORS I can use an Engine harness out of the following:
96-01 Tacoma
96-00 4Runner
Any year T100
A list of ECU part #'s I'm putting together that may work.....
(all ECU part #'s start as 89661-)
4Runner's
'96 4x4 M/T:  -3d140
'97 4x4 M/T:  -3D310
'98 4x4 M/T:  -3D310
'99 4x4 M/T:  -3D590
Tacoma's
'96 4x4 M/T:  -04220
'97 4x4 M/T:  -04310
'98 4x4 M/T:  -04410
'99 4x4 M/T:  -04450 or 04451
'00 4x4 M/T:  -04690
Any information would be appreciated. Being in California I have to deal with smog so trying to take my time and do this correctly to avoid any issues with the smog ref's.
GONZO97
I wanna watch, thinking of doing a 3.4 swap myself at some point
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
:welcome:  II  :turtle: I want to watch this one.
86bobbedtoy
voodoo556
#4
Been awhile since I've had any time to work on this.
I found a '98 T-100 4x4 3.4 manual 5 speed that had been rolled that I bought for a donor. Highly recommended to find a complete donor vehicle when doing this swap. I already had a low mileage 2000 3.4 out of a 4runner, and now I have another 3.4 from this T-100. I cant say how much help Mike from Off Road Solutions has been, awesome guy and tons of knowledge.
I mainly wanted the computer and harness for my swap but now I have some extra parts: 3.4 w/ 150k miles, 5 speed transmission/T-case, exhaust components, rear end, etc...If anyone is looking for parts off a '98 T-100 let me know.
I pulled the ECU & harness out, ordered my conversion harness from ORS, worked on the crossover pipe (used parts from all 3 to make 1) and changed out my oil pan (using the 3.0 pan). I snapped 3 studs on the manifolds taking the stock crossover pipe off the 3.4 so now I am going to have to drill them out and possibly re-tap. #joy
On another note, I came across a Dana60U rear axle the other day. Evidently the Dana 60U comes in E350's. Not sure if I will narrow it or go with full width. I sure wasnt planning on a SAS just yet but figured Id get to gathering parts as I came across them. Next will be finding a front end sometime down the road after the 3.4 swap is done.
On the 3.4 swap I am at a stand still until I get the conversion harness, which should be real soon. Mike at ORS expected to have it in the mail any day.
Will update when I can. Happy holidays!
Dingman.
Where are you located?   Whats the gear ratio of the rear diff on the T-100?
4-lo
ORS still in business??? Thought they went out of business.
AaronB
Wondering about the rear axle also.
