90 turned 87 4runner
Started by floorrunner, August 08, 2014, 12:10:15 PM
floorrunner
Been on here for a few years figured id start some sort of build thread. Bought a 90 4runner in 09 with a blown 3.0 and auto trans.
This is what she looked like when I got her.
Rebuilt engine, 5 speed swap, 33's.
87 4runner, 97 3RZ, dual ultimates, 5.29's air over elocker & arb, true longs R.I.P., York belt driven onboard air and a/c.
1985CRAWLER
wheres the rest? this is interesting!
floorrunner
Next came sas with 85 housing and single case 4.7 behind r series.
floorrunner
Then some 5.29 and 35's
First time to coyote...
Few broken birfs later....
floorrunner
#4
Then got tired of the gas hog and found a 97 rolled runner for 400.00 for my 3rz swap
Installed a 2nd fuel tank with Chevy fuel tank switch so I can see fuel levels and use both fuel pumps on both tanks
https://vimeo.com/102964791
floorrunner
#5
Oh and duals:-)
floorrunner
#6
Then December of 2013 this happened at bald, tomato rock they say? Not sure...
Then found this little gem tucked away at valley offroad.... Did some trading and we all know what happened next....
Some revenge.....
And then thanks to wal-marts rattle can section...
We end up with the 90/97/87 4runner
floorrunner
I'm sure this is somewhere but 8 of 10 body mounts were the same from 2nd gen to first and just need to cut a bit of room for the first gen fuel tank to mount up. Body fits like a glove.
floorrunner
#8
https://vimeo.com/102966705 knocking noise in video is hammering (background noise @ the shop), sounds like somewhere in the engine though, lol
Then installed a York compressor driven off the alternator pulley. The 22re Ac tensioner pulley welds onto it with the bearing removed so you can pass the nut through and still tighten it to the alternator.
Chuyota
floorrunner
floorrunner
Just ordered a winch, finally! My bumper has waiting for this for about 3 years now. Should be here end of week or early next.
LittleSteve
Refusing to fit in or comply.
Easy is not worth anything.
floorrunner
Quote from: LittleSteve on August 12, 2014, 12:17:04 PM
Nice rig dude. :thumbs:
thanks, they are lots of work and never ending.... Unless u have deep pockets, lol
LittleSteve
#14
I know, but then there is nothing else like it, i wouldnt have it any other way!
Is not just the trucks and parts though its all the tools and associated junk that goes with it
floorrunner
floorrunner
Thought I would build a roof rack, wanted to make sure I could fit the 10x10 easy up 63" long and most of the camping gear. Overall I spent a little over 40.00 in materials. It's 40"x72" I don't have a tubing bender and I thinking I may like the square look for the 1st gen runners. The dom bumper looks nice but depending on how the rear bumper goes I may pull it off and make a front bumper to match...
floorrunner
#17
Passing through Fresno and thought it would be cool to swap out maf sensor at autozone, (only thing open).  Hopefully we can make it to the con...
floorrunner
New maf sensor fixed the p0171...
Well we made it placerville so far.
1:20 am keep on truckin...
floorrunner
GONZO97
Awesome build man, having a lift like that must be nice. I had to use a forklift when doing body work shtuff! keep up the posts and the good work man
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
floorrunner
Quote from: GONZO97 on August 22, 2014, 06:08:11 PM
if you have the room i would suggest getting one, i picked it up off CL for 800.00. easy to install with help for lifting. a buddy and i installed it. just be sure the towers are parallel.
floorrunner
Broken knuckle ball at McR.
Got home thanks to marlin.
Then got a follow up phone call this morning to make sure we made it out ok, what a guy!
floorrunner
Options????
TG taco width with my ifs hubs?
Used stock housing with gussets that are fully welded, lol?
Or part it out and put a Dana 60 under it?
Suggestions????
OVRAROK
diamond or ruff stuff housing
1985CRAWLER
X2 on the diamond or ruffstuff,i would prefer a ruffstuff.. a TG housing will only last so long.
glad u made it out man! good meeting u!
floorrunner
Problem I see with those as far I know is you need to reuse your factory knuckle balls?
SNOW WALKER
Diamond all the way. And um..... how the hell did you do that? I'm running 42's for the last 4 years and have only bent a front housing. That was at our TTC with sagged out springs and waay to stiff bump stops. Oh ya and hitting 2ft logs wide open 3rd gear  double low. Dam frame twister. LOL
1986 4Runner turbo sas high pinion,E-locked 4:88's,taco rear Detroit locker,22ret forged everything,
duels mc07-r10 cut 42's.
floorrunner
Quote from: SNOW WALKER on August 25, 2014, 10:27:40 PM
IM THINKING THAT WHEN I ROLLED IT LAST DECEMBER THAT IT STARTED CRACKING FROM THERE.
OCD
That's the second time I've seen a ball break like that recently. Sorry we were of no help Sunday morning, but you have inspired me to invest in a mobile welder... Hope to see you out there next year!
