Anyone running dual batteries?
Started by Hurricaneinmotion, July 08, 2014, 08:13:39 PM
Hurricaneinmotion
 :usa:looking for ideas on placement of 2nd batteries anyone have photos?
We make a living by what we get, We make a life by what we give.
floorrunner
How about on the opposite side of your factory battery. If you have a pickup just weld a optima battery box under your bed, Optima batteries can be mounted in any position, even upside down because they are a gel cell.
Are you going to run a solenoid like rv type so it disconnects when the key is off, so incase your main battery dies you can flip a switch and it will send power to your main unit?
87 4runner, 97 3RZ, dual ultimates, 5.29's air over elocker & arb, true longs R.I.P., York belt driven onboard air and a/c.
Hour–Runner
I'm running duel battery's. But I'm also runnin diesel. The mounting of it is very simple just weld angle iron to make a base. As for wiring duel battery's on a gasser I'm lost sorry if this didn't help any. . . :_oops:
If you mess it up, or break it more than a few times THATS LERNIN!!!
megaphoneman
LittleSteve
shall i see if i can get the part number for the genuine tray out of a diesel truck? then you can just stick it in?
Refusing to fit in or comply.
Easy is not worth anything.
86bobbedtoy
Quote from: LittleSteve on August 09, 2014, 10:34:42 AM
thatd be clean
LittleSteve
These are the trays in my '89 theres a pot of peek on the drivers side
helipilot77
What year is your truck? What engine are you running?
LittleSteve
