Author Topic: 3RZ vacuum hose ?'s  (Read 11821 times)
UtahGuy
  • Turtle Points: -64
  • Member since Dec '13
  • Hooligan
3RZ vacuum hose ?'s
« on: Mar 15, 2014, 04:23:18 AM »
I'm neck deep in a 3RZ swap.  I've got most of my lines figured out, but there's a couple that are throwing me and I don't have a complete motor to look at, any help IDing these would be awesome.
1) I would have figured these two for the PS pump, but there's nowhere on the pump to put them?
2) These next two come off the bottom and top of the intake plenum in the direction of the drivers side fender - charcoal canister?
3) Brake booster?
4) No idea on this one, to the intake perhaps?
5) This coming off the bottom of the throttle body looks like a coolant hose, but I don't see where it wants to end up...
6) And on the intake tube itself:
This is getting pieced together instead of all coming from the same donor (I know, I know).  The block is '95 or '96 (because it has a distributor), I have no idea on the rest of this stuff, it's all coming from junkyards.  So I could have a mismatch of parts and have some hoses with no home?
1985 4Runner SR5 ~ 1999 4Runner Highlander ~ 2001 F150 SCrew
Ritchie
  • Turtle Points: 539
  • Male Posts: 267
  • Member since May '13
  • Ritchie
Re: 3RZ vacuum hose ?'s
« Reply #1 on: Mar 15, 2014, 07:38:04 AM »
Utah,
I have an '03, so I'm not saying all of these will be the same for whatever year of truck you have, but here goes:
Pic 1: My '03 does not have either of those.
Pic 2: Goes to smog equipment near the fuel tank.
Pic 3: Goes to smog equipment on the driver side fender well.
Pic 4: Goes to the brake booster.
Pic 5: Goes to the top of the valve cover.
Pic 6: Appears to be the bottom of the IAC valve. It goes to the EGR valve.
Pic 7: The smaller one goes to a diaphragm of sorts which is mounted towards the front of the fuel rail. Not sure where the larger one goes as I replaced my air intake tube with something I made but, my OEM air tube did not have that connection point. If your stock air box does not have a nipple that size towards the radiator side of it like mine does, that would also go smog equipment on the driver side fender well.
I work on getting pics posted for you.
Hopes this helps.
« Last Edit: Mar 16, 2014, 04:25:30 AM by Ritchie »
'03 Step side Pre-runner, F/R 4WU 3 linked, F/R Diamond axles, F/R ARB's w/5.29's, F/R Fox 12" CO's, ShrockWorks front bumper, self made rear bumper, WARN M8000S w/ remote, 4.7 Inchworm Lefty, MC sliders that hold air & a bunch of other stuff.
Crunchy Taco
  • Turtle Points: 90
  • Member since Sep '13
  • Flexiest leaf sprung taco I kno
« Reply #2 on: Mar 15, 2014, 10:56:59 AM »
Pic #1. The hp pow steer line on 97-99 has a valve on it for those. Just plug them off. I changed my pow steer line cause my other one got a leaker and the new one I got didn't have that wacky valve anymore so yea I just plugged those off
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
UtahGuy [OP]
  • Hooligan
« Reply #3 on: Mar 17, 2014, 10:01:55 AM »
Thanks guys, that helped a bunch.  Appreciate the assistance.
Ritchie
  • Male Posts: 267
  • Ritchie
« Reply #4 on: Mar 17, 2014, 07:09:37 PM »
Do you need pics?  If so, I need to make my photos smaller in resolution to get them on here.
UtahGuy [OP]
  • Hooligan
« Reply #5 on: Mar 18, 2014, 08:25:45 AM »
No, I think I'm good.  I'll hit you up if I get stuck again though. :)
onemanarmy
  • Turtle Points: 87
  • Member since Mar '13
« Reply #6 on: Sep 15, 2014, 08:30:22 AM »
Instead of making a new thread, I'll bump this one...there are some good pics.
In pic 3, there is a diaphram/regulator that has 4 or 5 vacuum hoses connected, and there is a nipple on the bottom....is there a hose that connects that to anything?    I've inherited a 3rz swap and am trying to get the vacuum stuff cleaned up.
Thanks
Crunchy Taco
  • Turtle Points: 90
« Reply #7 on: Sep 15, 2014, 02:25:58 PM »
I believe that hose hooks into the egr.
Crunchy Taco
  • Turtle Points: 90
« Reply #8 on: Sep 15, 2014, 02:33:15 PM »
This might help
onemanarmy
  • Turtle Points: 87
« Reply #9 on: Sep 15, 2014, 07:59:45 PM »
Thanks.  Mine is hooked to nothing (the single nipple on the bottom)   I'll investigate.
Great help.
Crunchy Taco
  • Turtle Points: 90
« Reply #10 on: Sep 17, 2014, 06:53:55 AM »
We'll if you don't have an egr valve then all those vacuum lines just need plugged, but if your egr is gone make sure there's not a hole in your intake where the egr is supposed to be bolted up. When egr is deleted the hole has to be capped off. And you'll get a code for exhaust gas recirculation being insufficient.
Nation
  • Turtle Points: 1141
  • Male Posts: 1,565
  • @nationallmotors
    • Buy me a soda
« Reply #11 on: Sep 17, 2014, 11:30:33 AM »
you can put a resistor on the egr sensor and fool it into thinking everything is ok. I saw a post on it somewhere. google that one.
onemanarmy
  • Turtle Points: 87
« Reply #12 on: Sep 17, 2014, 04:31:47 PM »
The EGR is gone, and the hole is plugged.
So I would need to cap all the lines that run to the 'connector'?     The rest of the system seems to be intact.  Would it be better to just replace the EGR valve?
Crunchy Taco
  • Turtle Points: 90
« Reply #13 on: Sep 18, 2014, 03:16:47 PM »
Yea plug all the hoses. And keeping it or deleting it is up to you. I deleted mine and I saw an increase in performance. That was before I was turboed, seemed like it woke my air intake up tremendously, But I get a cel, need to look into the resistor mod. Recirculating exhaust gases back into your intake is the same as farting in your mouth.
onemanarmy
  • Turtle Points: 87
« Reply #14 on: Sep 24, 2014, 08:03:05 AM »
The rest of my EGR system seems to be intact, the only thing missing is the EGR valve.    The smog box is still on the fender with the hoses hooked up and the electrical connections present.   Do I need to wire in the resistor?   and which connector is that done to?
Thanks
Crunchy Taco
  • Turtle Points: 90
« Reply #15 on: Oct 02, 2014, 05:31:48 AM »
I'm not sure I haven't done the resistor mod yet. I was goin to research if myself. I'm sure if you google it you will fine something but until then just run it. It will throw a cel though.
onemanarmy
  • Turtle Points: 87
« Reply #16 on: Oct 07, 2014, 12:57:53 PM »
I did some more digging.
The PO did the resistor mod and I now think all of the hoses coming off the emissions 'box' are now going to the correct place.    Once I saw where the resistor was supposed to go it was pretty simple.   Put the resistor in the harness side of the connector that used to run to the EGR.
cleared the CEL i was getting and now no CEL for a few hundred miles.
Ritchie
  • Male Posts: 267
  • Ritchie
« Reply #17 on: Oct 18, 2014, 05:11:26 AM »
Do you have any photos and what size resistor?
Thanks.
Nation
  • Male Posts: 1,565
  • @nationallmotors
    • Buy me a soda
« Reply #18 on: Oct 18, 2014, 07:13:33 AM »
10k ohm I believe
Last post Dec 12, 2004, 10:44:50 AM
by Fireimp141
Last post Jan 10, 2006, 02:27:16 PM
by toyrokcrwlr
Last post Feb 08, 2007, 06:47:54 AM
by Rockdiver
Last post Aug 01, 2009, 05:33:07 PM
by trucha
Last post Dec 30, 2014, 06:45:37 PM
by 87Fontana
